- 91 Notch what's it worth?
- Stalling
- My Review of the Baumann AOD ReCal kit...
- spark plugs question
- Head Gaskets?
- Head Gaskets?
- Is it safe to shift @6000?
- anyone got a cam
- 1986 Mustang GT
- Which Lower Control Arms?
- pro comp vs afr heads?
- lowered car
- 5.0 vs. camaro iroc......
- how bout it
- interior
- huzzuh another rims thread UPDATED WITH MY CAR ON prostars
- shift kit
- Higher Reving Engine
- 1986 GT need help with 93 5.0 install
- Need some input quick!
- which rockers are better
- trickflow stage 1 cam question
- Injector
- will this mod. put me in another class?
- Cobra Heads/GT-40s.. Thermator?
- I HATE AFR HEADS!
- What do you think of my Stang?
- Piston to valve clearance?
- couple questions plz
- pics after completion
- test
- mid 80s 302 motor
- Anyone know how to remove the brake booster pushrod?
- phenolic spacer
- how much hp 5.0
- keep or sell the stang?
- 24lb injectors
- grill or not???
- Whats teh deal with this dude
- pony rims question
- look what the mailman brought me
- Summit mass air flow sensors
- Ripped out the rear! Need input on what to get next..
- pic request SN95 with Louvers
- cam info
- Anyone Crack Their BLOCK
- Pic request- CobraR's on Fox with rear spacers
- tb size? will this hurt my performance
- t 5 to c 4 swap
- t5 transmission swap on 92 mustang AOD
- Saleen Rear
- Rims are here! 5 lug Conversion soon! Pics
- HEAD GASKETS-MLS WITH BLOWER
- lowering springs???
- S/C?
- Need Some HELP on boost
- Lost keys how can i start it up
- floor panels
- 302 or 351w
- Top end?
- Cam Question
- afr 185 vs. victor jr's
- Good Day.
- About to order some Bassani mufflers
- Driver's side door alignment...
- 351 windsor
- Window Thingers
- pushrods
- battery?
- Underdrive pulleys vs. Alternator
- Hatch question
- Damper?
- Info on this setup
- tensioner issues
- 5.0 Exhaust Sound Clip Thread
- Kenne Bell blower misfire
- What set-up exhaust is this?
- does this look right?
- whats a Intake manifold Spacer do???
- Heavy vibration under load
- backfiring?
- electric choke
- Bogging down with slicks?
- Should I port n polish my Track Heat heads
- LTs: BBK vs. Mac
- Grinding noise when I'm in reverse...
- Tire question?
- Headlight Switch
- Whining problem
- 87+ to 4 eye?
- Anyone who has done a 5 lug swap i need HELP!
- 88 GT 5.0
- video's
- Supercharger site
- What needs done to make an engine a stroker?
- My hood+intake rub together
- 9 lb pulley size????
- Best exhaust?
- 87 GT transmision ???
- 5.0 question
- help fast!!!!!!
- Power Steering pump replacement
- need your opinion/help
- Need a intake polisher in MD
- paint guys--gun question
- Gt-40X's shaved .25 what effect will this cause
- traction problems
- 5.0 guys in MA
- What would this car run 1/4 mile?
- Smog/ac PULLEY delete?
- Front Lower Control Arms
- quicky pic request...
- windage
- clutch cable PROBLEM
- Front tire ?
- Finally
- help in need a firing order
- 89 Notch, on hold...
- How many cold cranking amps do i need?
- Stroker HP
- Is This Paxton S/c worth the price?
- Installed Steeda Cable Kit
- interior resonace
- found some rust
- New car
- HP?
- question about oil
- will I have some problem with my 5.0 ???
- new gauges(pic)not installed
- 5.0 hp
- Question about parts
- What do you guys do to prevent theft?
- Thinking of getting an X-pipe but which one?
- 85's!
- wooohoooo!
- timing cover
- holy crap........
- Add Nitrous??
- 93 cobra motor and gt40 crate motor
- i have aod parts in the classified section
- Supercharger
- New Fuel Pump installed. Heat Issue now.
- 5lug swap done and wheels are on!! (pics)
- Cant get quadrant back in
- underd drive pully question
- xe274
- quad shock??
- coolant problem
- what kind of tires
- What fuel pressure
- powerdyne superchargers
- AOD to Manual shift 95 5.0 swap
- Another dam T-5 thread
- floor panels
- govern
- Problem wit my t-5
- power steering
- KB, HP 76 or 88mm Turbo, Novi 2000 or YSI
- axle damper for 92 mustang
- What do u guys think
- Was this a good choice?!
- c4 or c6 in a dd
- Advice needed: got some extra $$$
- 82 transmssion
- roller rocker arms?
- Engine Swap
- radiator support?
- Trouble Reading 347's oil dipstick
- prostars?
- harmonic dampener
- this pic is for you guys i found it
- Please help!!! 89 GT
- which one is good to do 1st
- 2 questions
- rims are stuck...
- Im sick of waiting for my engine to go! Paxton?
- 351 in a s 95???
- Who's dynoed before and after...
- 94' Tranny in a 92'?
- IAT Sensor
- how much $ for 92 hatchback
- need help on h/c/i
- Reduing engine compartment.. check it out
- What parts well hook my car up the best
- 351c heads
- 351w Noob Question
- Ford Racing Gauges
- Is there?
- 351 Cleveland or 351 Windsor?
- hi mileage 5.0
- 86 GT 5.0
- car sits uneven....fix
- The dissapointment
- 90 vert rear seats fit 87 hatch?
- Clutch question and tranny advice help please
- TKO600 or T56
- Need Recomendations
- suspension help
- what should i do ???
- Tapping oil pan...then oh sh*t
- Muffler ?
- which brake rotors?
- cams
- new shifter installed.....w/ pics
- what u think of my new wheel/brake combo?
- Eibach Drag Launch Springs w/Airbag
- looking for a car trailer
- is this factory?
- Please tell me what you think is wrong with this trans. I need help
- GT40 heads
- cam across an old picture too bad they are all totaled now..
- parking light and fog light mod?
- you guys going to the track
- Finally got the 5-lug conversion done, and 10th Anniversary Cobra Wheels on....
- bel housing question.
- Clutch please. I Need help
- 3.8 supercharger
- 1993 Mustang
- control arms...
- Heads question
- carb
- Maf Help!
- 4.10 gears
- a shout out to everyone
- Battery Spark
- Converter and Gears ???
- HELP ME PLEASE :-/!!!!!!!!!
- Is 9.5 slow for a Mustang
- puting it back together
- Which flywheel should i get
- 1/8 mile time for a Stock 5.0
- Installing Torque Converter to Flex Plate
- External Fuel Pressure Gauge--where mounted
- update on fuel pump problems....
- transmission
- tfi moduel help
- Different style overflow bottles
- Low Coolant Effects...
- no motivation thinking of selling
- Control Arms
- edelbrock H/C/I combo
- Firewall Adjuster Help
- What are all the symptons of a bad ECT & ACT ?
- INTAKE SPACER
- Is this going to be a issue soon?
- Paint Help!
- sorta new to 5.0's..couple ?'s
- low idle
- Pic Request
- where to instal switches?
