- Speedometer issuses!
- OMFGWTFBBQ about to start up my rebuilt engine...
- Spec Stage 3
- FI '89 5.0 into '91 4cyl
- MOVED: For all you experts---
- transmission
- crosshatching in cylinders with 227k?
- MOVED: head gasket replacement, pics
- MOVED: bfg drag radial vs. nitto drag radials?
- bad drivetrain vibration
- Heads, cam, intake, 1.7RR...???
- help with clutch
- Car won't stay started
- Running lean on left side of engine?
- Couple quick Q's
- 302 valve springs... HELP!
- WTB: 87-93 GT BODY KIT
- dirty top
- rebuilding a T-5
- 1994 steering rack
- final porting questions
- 4 Cyldiner Conversion Brake Booster??
- gear driven timing set
- t-5 to c-4 conversion
- flaming river? manuel rack?
- Best shocks/strut & spring set-up
- Heater Core Bypass "Properly"
- intake gasket, look at this pic!!
- Need help with clutch cable replacement
- Ashtray Spring
- Fuse Question
- GT-40 heads ?
- Odometer
- Dead Battery Again
- MOTOR MOUNTS /FANBLADE
- stock bore/stroke/rod sizes?
- clutch cable crapola
- Will this work?
- Fuse
- sn95 brake + 5 lug
- junkyard 5.0
- shimming a starter?
- how do i adjust the tps sensor
- Revving/shifting:
- running rough
- alt. bench testing, and a quick ?
- 351w iron heads
- Line Lock Install ?'s
- Getting rid of the fuel injection!!!!
- what effects do u notice
- Are 4-eyed GT & Lx bumpers different?
- drag spring, do i need cc plates
- fuel pump broke. upgrade or just replace?
- how could i keep this legal ?
- H/C/I startup help!!
- Any have a clue?
- my first fox body
- is this much water in exhaust normal
- cam
- shorter oil filter?
- 1994 Mustang
- starter grinding
- gas in oil?
- need help trying to get motor out to put the new one in
- Alternator replacement
- Cylinder PSI
- C clip eliminators install questions
- 19lb mass air flow meter with 24lb injectors?
- ADJUSTABLE ROCKERS
- how do you wire this starter?
- lincoln lsc
- Winter project--build up
- wheel alignment
- how to tell if gears were upgraded
- what do you think of CHP
- pedestal rocker question
- wings.
- 94 gt lifters?
- Rear Disk conversion
- Just ordered Benett Racing Motor
- caster and camber/ lowering springs
- Window switch.. I dunno
- HELP!!! I think ignition problem
- motor mounts plz help!!
- i don't have a door key
- auto to stick...change computer?
- Brake Rotors
- x-pipe and mil eliminater question
- Noise coming from my rear end.
- limiter?
- T5 specs
- fuel regulator problem
- Spring Install
- New guy to 5.0 ? on water pump
- drivers side power window
- T-top structure being safe from flexing
- rear end length question??????
- What valve covers to get?
- can't get car to idle
- trans problem
- thru the fender CAI
- Need a Dyno.
- sunroof problem!
- whats the shop time on headgasket?
- Poor Idling
- electric fan
- Lets put DSS blocks to the test
- 95 mustang new plugs and wires whats the problem
- 86 5.0 gt brake problem
- Carbon fiber top for 1988 gt vert? (or other removable hard top)
- charging problem...
- changing from head bolts to studs?
- 3.73 gear install
- Car Vibration
- gear question
- Piston Clearance
- tilt wheel wire splicing
- Body Help
- MOVED: First time! Don't laugh.. too hard lol
- red header
- One of my stock rockers isn't getting as much oil, and is kind of loose..?
- 410s blow your bottom end?
- MOVED: my new car
- ===> Performance mod HOW-TO'S
- ===>Common problems/stock performance/common mods
- Blinker problems - Hazzards no blinkers
- Lost clutch adjustment.
- Best fluid for Tremec 3550????
- nitto question.cant find in search
- heads
- Car is Bucking like a MoFo At Temp!!
- Turbo Qs
- Royal Purple
- 5.0 to a 351 ?'s
- where to find this
- has anyone tried this manifold>?
- I need help something is f*cked up (tps related)
- why are my interior lights staying on??
- KOEO code......
- compression and pump gas
- Tranny help...again
- can underdrive pulleys.........
- 89 LX 5.; stock MAF sensor on 70mm MAF?
- 410s and shift kit, traction problem?
- t-5 tranny fluid
- Driveshaft Question
- Fuel problems?
- Which parts will swap from sn95 to fox?
- rules about racing...
- Transmission leaking.....? UPDATED!
- 5.0 questions and cam selection.
- Please help me figure out what engine...
- ==>BOLT ON POWER WITH DYNO NUMBERS!
- parts needed for aod to t5 swap
- MOVED: new stang!
- temperamental
- MOVED: ACC carpet....yes or no?
- i don't know what happend....
- MOVED: Look What I'm working on
- MOVED: Tail light assembly question:
- equal lenght shorty headers
- Low throttle bucking
- rebuilding rear end
- Porting intake///heads?
- almost figured out my h/c/i
- hangin idle from hell
- problems past 4000 rpms
- good 5.0 tech in so cal
- Engine Balance
- Map Light install
- 98+ explorer intake and heads
- i cant tell
- Suggestions for rear shocks
- what size tire/backspacing combo
- engine shaking..but why??
- transmission
- fog light mounting
- Did I fry my alternator?
- Any experience with the Crane HI-6S igniton?
- Time for the power adders
- electric fan killin me here where to hook up?
- FI to Carberator
- explorer intake
- RPM sensor location
- 86gt efi to carb, what carb what intake?
- spark plug gap
- compression ratio?
- what will I need for gt40 heads?
- Not 5.0 but tech related.
- Compression ?s
- Starter question...and yes I searched
- Car hesitates when going from 1/4 throttle to full
- Air silencer
- need help with tire sizes
- What are the Bare essentials on stock 5.0 fuel injected
- Electric Fan Relay Help...
- nitto 555
- Cam question
- Stock 5.0 running rich, need help?
- next upgrade?
- MOVED: WOOHOO!
- help having problem.
- o2 sensor ? and a bolt ? to do with header install
- * RANT pg. 2*cleavor heads on windsor??? to do or not to do??
- 500hp 5.0??
- are these worth it??
- Just curious about you untuned folks.
- T5 Rebuild
- has anyone gone through them for an engine
- random peice of metal fell off my car today
- what gears do i have?
- Door/Window Issue
- Hesitation when at Operating temp!!??
- charging issues
- Looks like I have GT40 Heads
- lakewook bellhousing plate??????
- trans shift question
- Roadside issue
- Another Timing Question
- Engine stalling - choking - cutting off
- anyone try this intake??
- Tranny and Rear end questions
- injector ???
- 347 surging and pinging
- 1990 MUSTANG GT lamp conversion
- exhaust kit or just muff?
- Fuel pressure regulator size
- Tuning
- what tranny
- Signs of a bad intake manifold gasket?
- rollbar going in. seat delete?
- cobra vs. gt/lx
- Vibration after 65 mph
- fuel pump question
- mickey thompson et street......
- good estimate for rear seal replace?
- very small airfilter
- Timing Marks
- problem with warmup
- Help! problems with 5.0 install...
- A9P
- WHAT TIMMING YOU RUNNIN ON 347 STROKER?
- how to build a 302 efi??
- what cam?
- cam that doesnt require hci
- ahh help plz rear end is out of control
- pulling the 5.0
- Can I reuse?
- TPS voltage too high!
- new ege cupholder in sn95 ashtray?
