View Full Version : Classic Mustangs
  1. Timing Question
  2. Any advice or instructions for installing a trunk lock?
  3. some more mustang stuff..
  4. Coolant overflow problem
  5. Welding question
  6. reburbishing interior
  7. Wiring?? Painless or Other???
  8. How do you remove the trunk hinges? (67 CP)
  9. Duraspark II problems. Fastback is running like doo-doo.
  10. 1969 Mach 1
  11. switching sides...
  12. good info for us classic guys
  13. edelbrock heads 60379 heads on 66 289 engine
  14. 68 Mustang 78k miles value?
  15. H.i.d covertion on my stang.
  16. Bad Starter
  17. oil presure question redux
  18. 69 Mach 1 Exhaust Advice
  19. 1966 GT350 Clone Build Log
  20. OK, how do I get the antenna off
  21. Put motor oil in transmission
  22. what is the box at the front of the engine bay?
  23. Rearend problem?
  24. anyone have a block?
  25. i dont have to sell the 67' anymore!
  26. rebuilding carb
  27. Need help with loose choke stove tube
  28. Why am I still running rich.
  29. OT: my Halloween adventure.
  30. Side remote mirrors
  31. 69 Mustang
  32. Timing....?!
  33. Very Interesting Mustang find.
  34. 67 Coupe V8 engine compartment
  35. Steering for 1969 Stang
  36. anyone have a 4 speed toploader they're looking to get rid of?
  37. D/D must be crazy
  38. 72 Mustang grande??
  39. oil presure how much how little
  40. The deal of the century!
  41. Working on a Classic Stang?
  42. Looking for????
  43. OMG. YES ANOTHER ENGINE BUILD CHANGE!!!!!!
  44. Has anybody used one of these rail patches
  45. How to test for compression ratio
  46. 64-68 wiring & vacuum diagrams
  47. In case anyone is interested
  48. Ready for Rebuild:New Electrical System/Paint and Body?
  49. cleveland engine question
  50. got the car
  51. only 1 hi tourque starter??
  52. old newbie
  53. 1965 mustang gauge hookup
  54. picked up a 1965 fastback for roadracing.
  55. Spark Plugs Pics and Compression Test, Healthy Motor?
  56. Water Pump
  57. New girl...pictures
  58. What is this??
  59. 95 Mustang Cobra SVT Convertible/Hardtop
  60. How does this look? (carnage)
  61. Front disc brake conversion 1967: 4 Lug wheels?...
  62. 69 conv. can I hand crank it down?
  63. Small brake fluid leak(s)
  64. Hood Mounted Tach
  65. Battery Dying. Dx
  66. shelby c4 servo kit
  67. svt 4.6/t-5 into 1967 mustang fastback?
  68. 67/68 FB shell
  69. PROJECT -My New/Old Ride
  70. Please help identify mystery 351c air cleaner sticker
  71. Stopping power: CSRP vs. SSBC
  72. Chokostang or CSRP
  73. EFI + 351w??
  74. Need help with a 1965 289 rebuild
  75. Open House / BBQ at CPRstreetmachines!
  76. magizines
  77. Rebuilding a 351c
  78. 65 mustang suspension set up options
  79. 65 289 restor and upgrade
  80. Need recommendations please-broken window
  81. POR 15 Products
  82. anyone ever balanced driveshaft yourself?
  83. O.T.? Vendors and this forum
  84. 1969 Mach 1 with 535 horsepower
  85. autometer gauges.
  86. Question about hood hinges
  87. What do you think?
  88. Vinyl Dye?
  89. Newbe intro
  90. Radiator question
  91. Shattered Window in Washington, DC
  92. Nurburgring video
  93. 1965 carb rebuild
  94. 1966 gauges into a 1965 Dash
  95. Need Title Help...
  96. any reason this wouldnt work?
  97. Wiring help for a '66 Mustang
  98. My right headlight and tail light went out.
  99. Shop manual accuracy
  100. The Mustang Depot Stroker Kit?
  101. Narrowing 8"???
  102. Pre-axle turndown a problem?
  103. Convertitble Top Problem
  104. Sorry its a 390
  105. Machine Shop
  106. Does a 1973 F250 engine fit a 1967 fastback?
  107. '65 Fastback Brakes
  108. Still having wiring problems!!!!
  109. 66 C4 won't go into gear???
  110. non power to power brakes
  111. Starter system issues... please help
  112. Long term storage of a 302 (need advice)
  113. 1973 speedo cable removal, help!
  114. Need Shock tower measurments
  115. CPRstreetmachines Billet aluminum E-brake handle...Finished!
  116. EFI harness modification for 64 Mustang
  117. 200 ci I6 Manual
  118. Door watershield Question
  119. Brake problems 1965
  120. If your classic breaks down, be careful
  121. Help with Distributor Installation
  122. fun with a chevy engine
  123. 351 Windsor Engine
  124. 1969 Coupe restoration questions
  125. ned help with prices.
  126. Hey Sanborn, (or others) have a 65 PBrake Question...
  127. 8" installed, yoke question
  128. I need help... In a hurry.
  129. Grab-A Track leaf/coil suggestions for 66 GT fastback?
  130. Parts arrived today including engines!
  131. what color for my car?
  132. Lifters
  133. crane distibutor
  134. narrowing 9in?
  135. Undercoating soon
  136. New speakers. New Problems.
  137. Duraspark upgrade?
  138. Boss 302 carb spacer
  139. old gas disposal?
  140. Where can i buy Carb parts?
  141. Whats this?
  142. Shock tower repair time
  143. 5.0 from a truck into 65?
  144. holley design differences
  145. Galvanized frame rails?
  146. Seatbelt install
  147. Good Restoration Shops in New England?
  148. Fuel line / Vapour lock?
  149. wierd oil loss
  150. Drip rail quesions
  151. Building new speaker holder for the back
  152. Chineese parts...WTF
  153. Space Saver Spare Questions
  154. head size help.
  155. Rack&Pinion question..
  156. oil pressure question
  157. Rear quarter panel trim question
  158. Trouble with water pump install
  159. Looking at a FB
  160. My 1967 Mustang Project for sale in Ohio
  161. Can I put a '95 5.0 into a '70 302? Please help!
  162. Holley Carb question w/pics! (kinda large)
  163. Maaco paint?
  164. Plug Wire Suggestions?
  165. what is the right fuel pump for a 289?
  166. Block Sanding
  167. Can I do my upper control arms myself?
  168. Need expert opinions on a possible purchase-1969 convertible
  169. so whats a good slalom cone spacing?
  170. 351c engine build advice
  171. Spark plug wire mess?
  172. Header/Exhaust choices
  173. EFI kits? Any reccommendations?`
  174. paint problem =[
  175. Pony Carb 1100 Vaporizer
  176. I am staying here in Classic Mustangs.
  177. I need help with used suspension parts
  178. Power brakes
  179. Can anyone in Southern FL help me out?
  180. Are cars getting glossier
  181. 66 Fastback Suspension Question!!!
  182. 2 or 4 wheel alignment
  183. 65/66 Removable Fastback Hardtop
  184. 1971 302 engine intake and carb question
  185. Engine Outgassing, Oil and gas
  186. 64-66, taillight housing pads and gasket queston...
  187. Help needed installing rear view mirror, thanks.
  188. A couple new photos..
  189. What to hit it with?
  190. SN95 front brake mounting
  191. 351 Cleveland Engine
  192. Whats It Worth?
  193. Shelby letters
  194. engine compartment paint
  195. Does this engine sound right??
  196. 67 coupe parchment headliner question
  197. ford 9'' dissasembly
  198. Does anyone know...??
  199. mustang doors
  200. mustang doors
  201. '74 Gran Torino engine into '68 Fast back
  202. leaf springs ... again
  203. One mirror or missing one?
  204. Seafoam?
  205. Transmission for 377 or 383
  206. 9" Rear Question
  207. Desktop Dyno
  208. need a new radiator.
  209. In case anyone needs to.......
  210. Turbo Retrofit
  211. 289-302
  212. swap to vic frame possible?
  213. Where do you think oil is coming from?
  214. I6 to V8 swap
  215. Hesitation at Acceleration
  216. Quarter skin replacement
  217. any way to improve mpg on my '71 351C?
  218. 73 351C and Ignitor II
  219. Fender Strut
  220. Pleasantly Surprised!
  221. Anyone installed an independant rear suspension kit on a classic?
  222. a/c from 66' 289ci on 302ci Ford Racing engine
  223. new radiator help.
  224. engine cleveland or winsor?? from italy
  225. another Hyraulic clutch question.
  226. Pictures of Debbie at the Beach
  227. Hydraulic Clutch
  228. Mustang II suspension
  229. Going rate for a set of 69 Std seats?
  230. Martz rear chasis install
  231. pcv valve
  232. Roof...67 coupe
  233. Classic insurance coverage
  234. fun with holleys!!
  235. Wheels
  236. problems adjusting roller rockers
  237. BB toploader?
  238. Battery Advice
  239. Nice haul from Mustang parts yard....
  240. Boss 302
  241. Toploader Price???? Help, may buy this if right.
  242. Need Loan For Classic Car
  243. please help inherited mustang and wont crank
  244. 68 Original Wheel Options
  245. Gearing.
  246. NEED HELP ON PRICING
  247. 66 Mustang wood grain steering wheel restoration
  248. 05-08 seats ???
  249. Heater Core?
  250. Seat tags
