- YOu think this is a good buy
- rebuilding an AOD
- wierd problem with windoes
- t-5 tranny fluid
- MOTOR STOPPED RUNNING, BUMMING
- LOST NOS PROBLEM
- NEED 86 302 GT SFI EEC WIRING DIAGRAM
- intake mainfold question
- Axle shafts
- Brakes after 5 lug swap
- single turboing my 302
- Brake lights not working...
- question for the fella's who use anderson's p.m.s
- what goes where?
- 87+ fenders fit onto a 86?
- 94gt computer issues
- trany help please
- modern motor swap
- pcv valve???
- MOVED: Best Rear Shocks?
- MOVED: drag launch and air bag psi
- 5.0 cobra manifold install
- Exhaust Pipes Wont Line Up?
- Guage problems
- dead computers
- Question, please in really deep
- What makes more power?
- needs help!
- efi to carb
- Fuse Panel Diagram
- swap my 5.0 for a 4.6 or cobra motor
- typhoon intake
- gt40 heads on a sd motor?
- 89 alt upgrad Qs
- idle issues
- AFR 165 or 185's
- 331 stroker and injectors
- Oilpressure loss
- yet annother timing post
- MOVED: tire pressure?
- BLOWBY
- MOVED: just ordered some stuff from summit
- MOVED: estimate on repairing front end
- MOVED: can someone tell me what these are called and if they will fit my car?
- MOVED: i got 2 grand to spend....
- HEI distributor
- Installing Gauges
- How do you change front wheel bearings?
- THERMOSTAT
- Window gear problem, please help
- CAN'T GET THE STANG TO START
- HEADERS
- 347 stroker head???
- overflow bottle
- 3.8 to 5.0 conversion question
- running rich...
- An extra 302
- clutch quadrant + adj. cable
- Rebuild or Swap?????
- how the heck do i take the steering wheel off?
- B&M Transpack Kit or Just the B&M Shift Improver Kit?
- 2007 Wheels on a 1987
- Few Questions...??
- Stock Intake?
- fuel pump for carb q's
- Anyway to flush a Automatic Tranny?
- SRP pistons?
- headers & exhaust?
- 5 lug conversion HELP
- 94-95 5.0 better than 96-98?
- steering rack selection
- MOVED: Just bought a Bassani X pipe
- going into reverse?
- MOVED: torque boxes
- Supercharge with GT40 Y heads?
- I'm taking the distributor apart..
- SUPER BUMMER
- bottle heater
- 5spd 2 AOD..!
- why is this happening?
- fuel problem
- Already have 1.7 rockers-add E cam also?
- cigarette lighter question
- Cast Iron Heads?
- Little Help?
- Lowering w/o c/c plates
- pulled 4cyl now k-member install questions
- The "Fitty" is in recovery!!!
- MOVED: 1993 Lx to GT body conversion
- MSD box/distributor install question?????????
- last minute header questions
- which harness for MAF conversion???
- Blow off valve for a supercharger
- powersteerin leak
- Going dizzyless - How do U adapt Explorer CPS for 351W ???
- air silencer
- Nitrous(bottle in a bag) question
- what's the best way to change the motor mounts, and what's the rule for solid/poly?
- BBK fuel pressure regulator and guage
- intake manifold...
- car wont start?!
- C4 Questions
- vacum leak behind intake?
- Cams
- which would be easier?
- Why did this happen
- Front brake line.....HELP
- Interior Wiring Diagrams
- timing chain
- I need some advise
- Can these head bolts work
- heads, gt 40 or p heads
- Hey will this set up work?
- rattling??
- has anybody ever heard of this
- 87 GT Electrical problems
- ? containing oil
- AOD gears?
- MOVED: NEWBIE to the 5.0...Thinking of buying a 92 GT. Pros & Cons
- 89 5.0 gt, battery charge problem
- pictures of 351w swap long tube headers needed
- Are these springs too weak for my E303?
- Heads and Cam...?
- AOD T.V. cable
- K-member?
- fuel filter on '90 V8 5.0
- Questions
- why won't my check oil light go away?
- to port, or not to port???
- Camshaft suggestions please NO E CAM
- What should I get 4 Rear Suspension?
- SuperChargers
- backlash
- backlash
- New Grille
- one poor dead pony please HELP!!!
- ? about front torsion bars???????
- getting mad.....
- the motor is in, now I have trouble
- Installed a 1" intake spacer ? Improvement?
- fuel pump problem?
- Sick stang... crankshaft probs?
- How's this combo sound?
- Plug wires for equal length headers....
- 87 5.0 gt is it an interferance or non interferance
- do i need bigger fuel pump?
- fuel guage problem
- Throttle body coolant line
- Fuel Pressure questions
- Switching 19lb to 24lb injectors
- Exhaust leak or normal?
- trick flow or AFR heads??
- Shift Kit
- Header Gasket Install
- Anyone Ever Used These Lifter Supports, Never Seen Them
- 5.0L in 2000 stang...possible?
- Exhaust Gases!?!
- DOUBLE POSTING
- bad temp gauge or something else?
- Rack and Pinion?
- FPR fubar?
- manual rack kit????
- Need help on some rack&pinion bushings.
- ahhh ..... come on Pro5.0SC
- MOVED: Paint time
- MOVED: wanting to get a New convertible top
- 3.73's Installed!
- MOVED: Best engine stop leak??
- My Mysterious 331
- next mods to my 91 gt 5sp?
- windsor sr cast heads
- sn95 dash in a 89 LX ?????
- ATCO NMRA Pre-Cruise
- 1996 Explorer Intake Elbow
- O2 sensor
- Rebuild time
- I hate brakes! Any help very much appreciated!
- help finding parts???
- Cammed
- transmission pin needed for my 5.0 trans
- H-Pipe or X-pipe?
- trick flow kit
- Tranny question.
- Torque converter
- HELP!!! Anyone with a E303 & ped mount RR's
- Cheap Battery Mount for Trunk
- overheating
- tuning with a s/c. HELP
- 15x10 6.5" BS Weld Prostars MT Drags 26x10x15 need a lil info
- Explorer lower intake ?
- ecc IV codes - need help
- New exhaust not fitting properly!!!!
- Rear main seal/pan gasket
- SSBC
- Will 5 lug 15" new edge V6 wheels work on the back of a fox?
- Lifters
- gt front bumper for sale
- world heads?
- having trouble firing motor
- HCI done #'s are in!!!
- Pistons in an 85 5.0
- bad suspension setup
- Should I get my Cobra upper extrude honed?
- Stereo Static after installing Ford Racing Wires
- traction lock Q's
- rotors and brakes
- got some upper and lower control arms for free but i dont know who's they are
- Window question need help asap...
- Cobra MAF
- Wipers
- Power Steering
- Switching tranny from auto to manual
- Explorer Intake and Rods ( 98-2000 )
- Door ajar/Light's on Beep
- thunderbird tranny question!
- Short belt
- Gear problem?
- Heads and cam
- Stroker??
- speedometer help
- e7 heads on a 86 block??
- new fuel pump ?
- Anyone ever ran these heads? 32v for 5.0l
- ford 24# injectors
- valve adjusting
- no spark.... Help
- window motor
- hp and torq
- Torque Converter ?
- Headliner replacement
- about $4,000?
- A few questions from a beginner...
- different year t5
- Questions about upgrading brakes! HELP *PICS*
- judgement on engine kit
- running cold
- stock tach
- WHICH CAM??????
- Hushpower II Mufflers
- T5 install question
- spool or not?
- need some help with suspesion
- When do you need headers?
- Cam Question
- 306SB Procharger Build up PICS... Also question..
- hci swap
- Summit headers? Are they any good?
- Whats a good cam?
- Is this a good flywheel?
- best ecu/ecm for a 408w
