View Full Version : 5.0 Mustang
  1. What can cause it to no fire on all cylinders?
  2. 5.0 Question
  3. h-pipe rubbing
  4. TPI Sensor Help
  5. no spark issuses
  6. Adj. Alternator bracket ?'s
  7. Vibration at 65mph after rearend rebuild
  8. 1989 5.0 convertible help please!!!!!
  9. Brake line quesiton
  10. Strange Spark plug in supercharged 5.0
  11. Header install this weekend
  12. Anybody have one of these?
  13. Heater Hose Help!!
  14. computer rpm fuel shut-off
  15. Missing on cyl#2&3
  16. 351w head gaskets on my 347?
  17. Battery Draining Problem
  18. Porting heads...
  19. What plugs for gt40 heads?
  20. I need aod help
  21. Differential Carrier Shims.
  22. R&R rear end housing bushings
  23. Need help about to purchase first stang!
  24. need ID on heads?
  25. 5spd swap no start!!!!
  26. Possible pressure plate or throw out bearing problem?
  27. Fiberglass hood install, any help appreciated
  28. alternator pulley removal ?
  29. Milky/foamy power steering fluid
  30. MAF & Throttle body
  31. Dragracing with T5 transmission
  32. 1987 5.0 GT MANIFOLD QUESTION
  33. Motor Swap Different ACT Part
  34. Bad charcoal canister??
  35. Edelbrock Aluim. o-ringed heads.
  36. can i re-use this stuff
  37. driveshaft is too short????
  38. Rear end rattle?
  39. Supercharging My Mustang
  40. drivers side mirror
  41. 1995 Superchargers
  42. Fed up with exhaust, need to replace
  43. Will this distributor fit?? HELP!
  44. What oil after break in?
  45. 1989 mustang 5.0 GT gauges
  46. over kill or headed in the right direction??
  47. neutral safety switch
  48. Mustang build-up suggestions?
  49. to supercharge or not to supercharge
  50. 5.0 Heads?
  51. is this overheating? 233 before t-stat & 240 after T-stat
  52. POLISHING TROUBLE AND which cast iron heads to use plus intake
  53. what injectors have a white top?
  54. Strange Strut Question
  55. Coolant Overflow Bottle
  56. Cooling fan problem (need help)
  57. bbk clutch cable questions
  58. 89 GT carb conversion no start
  59. Driveshaft question
  60. Camshaft or Heads??
  61. Turn Signals Not working
  62. PCV valve hose location?
  63. Speedometer gauge going nuts....?!?!
  64. Flywheel Dilema!
  65. door gap
  66. Identifying stock heads
  67. 1994 GT Tranny problem
  68. 94 Mustang T-5 Bellhousing
  69. Lack of performance, Help!
  70. Time for a New Carb + Intake manifold
  71. My New 1985 Mustang Gt 5.0
  72. which intake to use with my setup?
  73. Went to track, huge power loss
  74. NITROUS GUYS!!HELP!
  75. aerospace brakes and windsor jr heads
  76. turn signals screwy
  77. AOD questions
  78. Please watch....
  79. odometer question
  80. where did my thread go?
  81. HELP PLEASE
  82. door hinges
  83. window bushings
  84. Mods and Cost to get a stock 302 to 400rwhp?
  85. Weirde noise coming from passenger side of engine...
  86. Question about double hump crossmember.
  87. proper way to set up roller rockers?
  88. Stang will not turn over! KILLS ALL POWER
  89. vibrations at high speeds :(
  90. do i need 24lb injectors?
  91. Lacking power
  92. Tap,Tap,Tap--But Disappears Quickly??
  93. Exhaust/misfire problem
  94. Qestion about my aluminum GT40 heads
  95. transmission problem????
  96. 24# or 30# Injectors?
  97. notchback 4 cylinder to 302 swap questions
  98. mass air ?
  99. MSD Billet distributor position help
  100. convertible top problem 92
  101. 1995 S281 Spoiler/Wing
  102. strut problem
  103. New 4 eye, now not firing on all cylinders...
  104. 5.0 wreck/rebuild
  105. LOSING POWER
  106. Need Mechanic in Greenville SC 82 EFI stroker
  107. Car wont start....
  108. Tell Me Fellas.... Is This Good?
  109. Setting timming
  110. ignt. module
  111. code scanner help!!
  112. cold plugs.
  113. new cam?
  114. HELP!!!.....What should i do next??!!??
  115. Stupid question.. What MM size bolts are on stock h pipe?
  116. EFI swap?
  117. where is the horn relay on a 92 mustang 5.0
  118. speed dens to mass air
  119. want to bleed the brakes, kit any good?
  120. 95 gt overheating update!
  121. lean at wot, but only in closed loop
  122. HIDS problem
  123. 5/16 guideplates pushrod diameter?
  124. big problem
  125. Is this a good water temp gauge?
  126. t-5 vs c4
  127. 97 cobra rear, problems/questions
  128. cheap road and track car
  129. adding .030 to pushrod length?
  130. Same as below, different scenario...
  131. Diagnose my ignition problem!
  132. Help with this timing light??
  133. Using a car dolly??? HELP!!!
  134. What Seals or O-Rings for Power Steering Pressure Line ?
  135. what headers with Gt40p's
  136. gas gauge
  137. HELP NEEDED--Brodix Track 1 Heads and intake issues
  138. idle problems!!!!
  139. Another AOD story...
  140. missing at full throttle
  141. A/C Delete
  142. rocker adjustment?
  143. rear end housing bushings, spherical or poly?
  144. is this truly plug and play????
  145. 93 LX Ignition Woes
  146. i just removed the a/c
  147. AOD experts, come on in!!
  148. car has a knock
  149. maf question
  150. Cold air and throttle body
  151. Cleaning a MAF sensor
  152. High volume oil pump ???
  153. need some help with intakes
  154. need forums advice..
  155. Gas vapor leak.
  156. new hatchback?
  157. motor problems
  158. F my life...
  159. max compression
  160. Idle Surge Problem
  161. car cutting off
  162. 95 gt over heating problem, im puzzled!
  163. need help with my t-5
  164. Ford Racing blue silicone hoses
  165. will it b ok to run a spool on the street.?
  166. question: i just removing smog and a/c
  167. TKO 600 Trouble
  168. Help!!! Throtle cable problem
  169. starter help...
  170. How to tell if control arm is bad?
  171. Turbocharged or Supercharged?
  172. 1995 Mustang V6-V8 Swap
  173. Summit Brand U/L Control Arms & Wheel Hop
  174. Need Help Now - Frustrated and Ready to Part it Out
  175. Clutch cable routing
  176. 95 GT going Carb
  177. need advice soon
  178. rear end and gear ?s
  179. Where to buy?
  180. C4 question
  181. Delete smog and egr on my 95 please help
  182. 88 MUSTANG 5.0 302 problems/help plz
  183. Bogging under acceleration
  184. will a gt40 intake fit on...
  185. bad computer?????
  186. Turbo
  187. 1.6 rr's with stock springs?
  188. What cam to run w/systemax heads?
  189. Carb Conversion - Looking for experienced help
  190. new plugs?
  191. Engine Setup, for my 1988 GT
  192. Are these required?
  193. gas gauge not working
  194. Check engine light comes on while accelerating
  195. how fast can you take 1st gear in an aod?
  196. harmonic balancers bad. which one
  197. Will 05 rims fit my 95 gt
  198. Water boiling over pretty bad..
  199. 1984 mustang intake/carb decision
  200. 3.90 or 4.10?
  201. 302 general knowledge question
  202. Gauge cluster question
  203. cyl #3,6,7,8 not firing. spark but no fuel
  204. V8 Compatiable Transmission
  205. Reverse Lights Out
  206. Think my rotors are warped
  207. coolant leak
  208. new egr valve
  209. E-Brake Light Stays on
  210. Bog Problem
  211. Putting a 429 into an 88 GT
  212. check engine light
  213. Have a 95 GTS Please help
  214. Help...not sure whats wrong
  215. driver window wont roll up
  216. 24# injectors and 80mm Granatelli...worth the hassle?
  217. 04 mustang GT into a 87 notchback
  218. Idle issue on startup
  219. Do I need to get my car retuned?
  220. I think my computer is fried help!!!
  221. Shift kit
  222. Anyone have a 94/95 pcm pinout or link?
  223. starter problem
  224. F.I. to Carb??
  225. Obnoxious Vacuum hose
  226. idle problems/acceleration problems
  227. temp problem
  228. Fox Heater Core AC and Box INTACT?!
  229. smoking wire
  230. trick flow valve springs
  231. delete spoiler
  232. new cold air intake?
  233. wake up AOD
  234. Suspension help for a '94 GT convertible w/ 18's
  235. heads???? AFR, DART, trickflow, edelbrock, holley... whats best?
  236. Slipping rear end?
  237. compression vs crank issue?
  238. motor swap ecu question.
  239. Question for the good engine builders
  240. Rotating assembly issue
  241. Trick Flow Package Deal
  242. 1995 Cobra Bodykits
  243. problems with my t-5 =(
  244. More H.P!!!!!!!!!!
  245. New Exhaust???
  246. 85 non roller motor 30 over build, looking for ideas
  247. Broke a valve spring.. do i need my heads machined??
  248. Dyno tune shops in NJ?
  249. Hey Whats up Guys!! ?'s On Speed Density!!!
  250. new motor and new problems
