View Full Version : 5.0 Mustang
  1. throttle sticking help
  2. Headlight bulb change?
  3. Adjustment for hatch?
  4. 4 catalytic converters and a popping noise.
  5. 5.0 swap
  6. 351?
  7. Crankshaft damper retaining bolt
  8. What should I get
  9. x pipe doesnt fit?
  10. Slight Miss....wtf!!??
  11. how restrictive are stock shortie headers??
  12. need help with a purchase
  13. 95 performance
  14. tire question
  15. Clutch problems
  16. spedo cable?
  17. will bbk shorty headers fit on gt 40p heads
  18. MSD digital Window Switch...
  19. Gears?
  20. Replacing Sender Unit in Gas Tank
  21. Need help with AOD Kickdown cable
  22. 351 Windsor Heads on a 5.0
  23. Rear shocks?
  24. MOVED: 95 Civic
  25. a few questions with the HCI install
  26. K Sport Springs
  27. cobra R hood....
  28. wheel offset and backspacing question
  29. what to do next?
  30. Goal: Low 11 1/4
  31. Leaking oil
  32. i need some help from you fuel injection guru's
  33. Best cam?
  34. Belt Tension
  35. problems with my 89 gt
  36. Can't get shorty headers out.
  37. Too much crankcase pressure
  38. Setting TPS
  39. quad shock removal
  40. Replacing fuel pump on a 91 LX
  41. Fuel line problem
  42. Trickflow lower intake gasket
  43. Help me! I've lost ignition
  44. cam and tuning help in a 94
  45. its hot need help with a/c
  46. Is this dry nitrous kit any good? Compucar
  47. Lower intake/ Fuel rail issue
  48. Rebuliding 5.0
  49. MOVED: cobra r rims
  50. Quick Spring and Strut Question
  51. Leaking fuel pressure??
  52. Rev Limiting a Carb Setup
  53. power window fix
  54. Strut & Caster Camber plates won't fit???
  55. steering column wont go back on?
  56. 5lug question please help newbie
  57. Tranny Noise
  58. anti lock light?
  59. 351w dates
  60. Poor 60 foot times
  61. 85 GT premium sound install
  62. A few suspension Q's
  63. gears with a c-4?
  64. Injector wiring harness help
  65. clutch, clutch cable, Qaudrant?
  66. Can I reuse my head bolts?
  67. Strut Bushings
  68. What cars can I take a T5 from
  69. aftermarket door handle fix
  70. t-5 question
  71. Somebodys gonna know this.
  72. Running too rich.
  73. Installing MSD Ignition w/MSD Boost Retard
  74. what cam
  75. sn95 bumber cover removal
  76. carb. distributor
  77. Check Engine Light(HELP!)
  78. dist. question
  79. Link for T5 replacement DIY
  80. AED carb rebuild kit???
  81. HELP! Auto Meter Speedometer Install
  82. Lowering Problems! Help!
  83. Fuel Pressure
  84. Ford Racing A/C delete kit ??
  85. Hard Start/No Start when hot? - Help
  86. what intake with cam??
  87. RPMs drop to 600 at start up...sometimes?
  88. MAP vacuum line
  89. Whats a good Epoxy to use on metal and fiberglass?
  90. non adjustable valvetrain.
  91. Engine balancing question
  92. aluminium driveshaft
  93. 94-95 Cobra bumper question
  94. T-56 Swap
  95. Taking lower intake off...
  96. Headlights
  97. blower style
  98. cnc ported afr 165's?
  99. MOVED: Estimate on times?
  100. rearend swap ?
  101. Need help pluggin coolant line from water pump.
  102. best mod for low end torque
  103. Dextron 6 anyone???
  104. advancing timing
  105. MOVED: 1/4 times for 350hp
  106. ultimate test for electrical mastermind
  107. New Barry Grant Mighty Demon Woes
  108. KNOCKING!!! ARGGHHH
  109. More issues with my O2 sensors.
  110. what happens with the belt...
  111. Can someone tell me what this is? Picture inside
  112. How are the stock heads?
  113. What is next?
  114. Fuel System Help
  115. Bypass smog in CA
  116. Loss of second gear?
  117. Getting a little vibration
  118. 94 Cobra Specs ?
  119. distributor install for an idiot that didn't mark anything
  120. Explorer head swap?
  121. I'm a Banned member returning under a new s/n.
  122. Seat identification and questions...
  123. cuple noob questions?
  124. GT-40X turbo swirl aluminum heads
  125. air cleaner cover
  126. continuing problems
  127. Better MPG?
  128. overheating?
  129. 351 Windsor Build Up
  130. rear end
  131. what would it take? GT headers
  132. 8.8 Weight
  133. Total timing how much?
  134. crankshaft
  135. once and for all..e7 heads on a 86 motor! will the valves interfer?
  136. biggest tire for 17x9 4 lug?
  137. Head Gasket Recommendation
  138. Odd noise
  139. gas mileage
  140. Bellhousing, flexplate help
  141. I want 500hp
  142. msd radio noise
  143. Dyno Tune results
  144. Changing a fuel filter
  145. re:would 02 bullit wheels fit on foxbody
  146. Decode Block Number???
  147. injector help
  148. WTF?? gasket ... water pump ...timing cover??? confused ...
  149. time for a rebuild but...
  150. Knock at start up
  151. i need help fast
  152. TWIN TURBO EBAY KIT???
  153. notch pistons
  154. Radiator help!
  155. Question about 86' flat top pistons...
  156. Electric Fan Set Up
  157. Rear disk brakes
  158. '78 302 with 60k miles...
  159. 10.5 OUT BACK
  160. bbk adjustable cable adjustment
  161. IAT causing problems!!!
  162. Frame connector question.......
  163. White smoking during hard acceleration
  164. Quick battery relocation ?
  165. manual rack
  166. Need help
  167. running lean like mothaa
  168. FR500
  169. low voltage... need help please
  170. Oil Pressure drops drastically WOT
  171. 18x10 Saleens rubbing with 295/35s any solutions?
  172. What gear set do i have on a 95 gt??
  173. bad idle = vaccuum leak?
  174. Shorty h-pipe???
  175. 89 lh mustang
  176. Open diff to Trac Loc
  177. Signs of bad suspension????
  178. throttle body?
  179. Rings?
  180. MOVED: what kind of tires you all running for skinnies
  181. Done first?
  182. instrument cluster voltage reg
  183. cuz no one in general wants to help
  184. speedo showing way too fast
  185. Here is a dumb question from the peanut gallery
  186. complete 97' explorer rearend ?
  187. I need help finding a lower intake for my box
  188. SD to MAF?
  189. subframe connectors
  190. autometer gauges go crazy when dimmer switch is moved
  191. Fly wheel balance
  192. wortht the extra money for long tube
  193. new motor
  194. Weiand Supercharger
  195. Getting some suspension work done...
  196. Scored at the junkyard
  197. Pinion gear
  198. 84 mustang start issues
  199. OH NO !!!!!!
  200. bigger injectors?
  201. i should know this
  202. gas pedal doesn't feel right
  203. Fuel additives?
  204. Exhaust BBK Q's
  205. TFI Moduel
  206. cam retainer plate
  207. holley info
  208. newer alternator failing again...whats goin on??
  209. really bad idle surge
  210. AHHH AOD IS DEAD!!!
  211. clutch fork leverage settings?
  212. rear strut tower brace?
  213. I will snap... leaking ....
  214. *update* Last chance with valve train noise *w/ vid on pg 2*
  215. what else could be causing the stalling?
  216. door handle broke
  217. Exhaust Question Help Fast Please !
  218. Possible to govern one??
  219. I need help on Rocker arm selection!!
  220. Question About Hoods.
  221. guestimated numbers
  222. MOVED: What motor oil are you running this summer?
  223. 302 Aluminum Heads Please Help
  224. MOVED: Myrtle Beach area.
  225. Changing oil pan gasket. What else to do?
  226. tranny fluid for TKO 600?
  227. replacing cam
  228. help, i'm really frustrated
  229. MOVED: bump
  230. Temp questions
  231. F-303 Clearence
  232. 5.0 that has Chevy pistons in it! wtf
  233. getting the stock tach to work
  234. Why does the power suddenly kick in?
  235. piston to valve clearance
  236. timing??
  237. Idol problems please help
  238. horsepower ratings for stock block??
  239. Cobra Brakes?
  240. electrical problems
  241. putting oil pan gasket on with engine in
  242. MOVED: 87-96 5.0 5 speed
  243. breaking up around 5200rpms
  244. Window Louver Question
  245. MOVED: check this out!
  246. Stock Rockers
  247. location ??
  248. Aod problem
  249. torque box reinforcement
  250. best heads for my setup
