- Scat vs CHP 347
- Engine Coolant Temp. sensor Run Rich
- Is this smell normal without cats????
- Dizzy Stuck
- GOT IN TROUBLE AGAIN
- runs realy rich????
- believe it or not
- anyone have the 3in. flowmaster kit?
- F150 Question (cant get answers elsewhere)
- Head Cover Bolts?
- STILL GOT A VIBRATION...ARGGGG!!!!!!!!
- bumper covers!!!!
- cold air
- Fuel injector?
- HID light ques..
- rear end
- MAF Sensors
- hey everyone
- What do you think my car would run in the quarter mile?
- actron
- Block work.
- swap my stock heads with a friends explorers gt40p's??????
- tire size
- yet another problem
- Tuners In Massachusetts
- Fog Lights
- spout connector
- Am i F*cked
- I smashed it up.
- check engine light question
- Engine rebuild
- remote start removal
- What set you off?
- how do i tell if i have a 331 or a 306?
- pictures
- Strut help
- any suggestions on which pistons to use?
- What color to paint it?
- Anyone live near Chico, CA
- Southside Machine Co. (SSM)????
- hey guys i'm back.
- Modding Plans For The New Year?
- Caster camber plate installation
- Anyone Running a Powerdyne
- 2 quick questions
- all the carb guys help me
- 95 5.0 hydralic clutch?
- Fuel Pump question
- ford explorer tb
- Rear Main Seal
- just painted my manifold
- Need parts list for a 96 3.8 - 95 cobra 5.0
- Throttle body and Mass air sensor quistions
- Hurst Roll Control ???
- Dumb question about drag tires
- cobra hood on fox
- Where can I find...
- What is my stuff worth?
- Cold air intake Difference?
- 351 Q&A
- Brace above engine
- cleavland heads
- Ponies?
- will blackouts fit aftermarket tail lights?
- Am I reading this corretly on how to plug smog pump pipe holes in heads?
- GASOLINE - Your favorite brand?
- stock gears???
- hood
- Hurst Billit Shifter
- what to do first?
- Turn signal problems
- cam in 87 GT air density
- explorer heads and intake info
- shift kit
- Disappointed..
- 28x10 tires
- which tail lights? lx or gt
- Ported stock intake VS Cobra
- MASS AIRFLOW -VS- SPEED DENSITY
- aftermarket coolant temp guage
- Front clip
- woooo ordered my trans!!!!
- Carpet Kit
- thinking about selling 92 lx for 97 Cobra
- Airbags
- What carb setup/parts to use?
- decisions decisions what engine combo?
- Custom gauge cluster
- altenator question
- want a laugh?
- Thinking about selling...
- whats a good clutch
- whats the probalittly
- bigger vavles
- Need Help.
- About to order my rear.. Need A Quick Answer!!
- static electrizity causes heater core failure?
- Hanging Idle HELL!!!!!!!
- what yall think?
- next mods to do
- u-joints...
- Stand Alone Ignition....
- My car's exhust video
- Wow it hauls ass!
- Transmission fluid?
- best clutch cable?
- C4 or C6??? PLEASE HELP!!
- 88 fenders on 93?
- Wiring Question
- 4.10 gears?????
- question
- 85 Seat Head Rest Removal - HELP!
- water build up in the valve covers
- huh?
- trans is acting odd
- Turbo Setup
- suggestion please!!! asap
- 'Freshen Up' an '89 5.0 HO?
- engine codes/check engine light comin on
- HAVING TROUBLE WITH MY 84
- 5 Lug disk brake conversion
- Is this normal
- Harmonic Balancer Question ??????
- Holley Intake
- 3.73 speedo
- Moon Roof
- fuel economy
- HElp
- 86 1.7rr with flat top pistons
- New VC's with RR heads?
- intake time, want opinions...
- what is this called?
- dyno tuner
- Bleeding....
- Car won't start, timing issue please help
- 85 5.0 4bbl Carb Help
- Radar Detector
- oil seal
- What Brand Spark Plug ?
- wiring diagram
- Fuel Pump
- big head rests
- what do you think??
- 7.5" rear end gears
- Valve covers
- Wideband o2 Controllers
- DSS VS. R302 Vs. Dart Black
- What to look for
- ok guys this is what i have......
- My motor plan.
- Adjusting TPS with car on
- rear end help (what should i do)
- pros cons on lightweight control arms
- what is better to start a project with? 4 cyl or 5.0?
- dadgum spring question
- cleaning heads
- would my car lift if...
- guys please help
- rearend's leaking...
- Headlights
- 5.0 probs help
- another head question
- Short Belt Question
- G-tech
- Hey I need some help guys quick
- can you make good power working stock heads
- 5.o vs. m3
- Long Tube Headers and Emissions
- cam install
- DSS
- Big cubes...
- So what would you do?
- 8.8 Rear internal swaps
- Single Vs. Twin Turbo
- GT fenders on an LX
- whats a really good way to make power?
- exhaust
- Rear Axel: 7.5 vs. 8.8 vs. 9
- Balancer weight same 88-95 ?????
- fuel vapor can
- GT40 heads really worth it?
- just heads?
- Approx Value
- missfire/backfire
- MAF Conversion
- I need cam suggestions
- H.O. diff Inter
- another tko question
- clutch ques...
- another piece to the puzzle
- big cam
- Thermostat Currently
- Computer
- 125 shot on 331
- gosh darnit
- smoke!
- the cam choice for the 86 stang
- Boss 302?
- engine woes
- e cam for 86
- Any clue Where this goes or what it goes to?
- rear hatch button
- original owners
- Short Belt
- Saleen RRR
- is this a good deal
- will not stay running
- Buying another stang!!!
- need new heads?
- how much is this worth?????
- King Cobra Clutch Kit
- 16" tires
- is it safe to remove screen in the mas air???
- 15x10 wheels on a 89 fox
- Dumping your Foxbody Exhaust
- 5.0 question
- Paint
- I'm about to give up hope with my car
- Long trip with the 5.0 what to look for before i leave?
- $$ VALUE FOR.......
- rims
- 302 with 4.125" bore?
- Bought many new mods/parts have a few questions
- who wants a free hood ?
- Arao 32 valve cylinder heads
- whats the difference?
- loss of power
- 94 COBRA..?
- is black interior really rare?
- which supercharger?
- T-56 6 speed
- rims on my 91 gt
- throttle body spacers
- jerking and bucking
- looking to buy 1993 Mustang
- what oil to use
- Distributors?
- Problem
- myy windsor project update
- what to buy??
- how big lift?
- smaller tires?
- lowering the front
- WHAT THE HELL IS IT?????
- Rims size, look?
- shift kits
- Dont know what to do?
- AOD TO C4
- shifters
- 4 cyl swap
