View Full Version : Classic Mustangs
  1. how much could i get for my 70' fastback?!?!?!?!
  2. I hate meeces to pieces.
  3. was there a 427 in 65'??
  4. 65' resto questions...
  5. Bad Judgement???
  6. Need Electrical Help Fast =(
  7. Transmission Question
  8. 66 brake lines
  9. 66 sway bars
  10. Scratching and running temp question.
  11. My Problem Sounds Like This
  12. AJE Racing setup, 351w and oil pan question..
  13. Old Mustang W/ New Model Fenders
  14. wrapping headers. opinions/experience?
  15. 68 Coupe - which hood scoop?
  16. Off Topic, but a pic of a mint SSP Police Mustang my Uncle has...
  17. 11.7:1 to high compression?
  18. 66 headlights on,..parking lights off?
  19. Whats the problem?
  20. Header problems
  21. rebuilding door hinges
  22. Cowl cleanout
  23. Brakes question
  24. Header size for a street 302?
  25. Gauge Cluster Circuit Board
  26. Media Blasting in Portland
  27. Louvers & Deck Lid Spoiler
  28. Paxton Blower
  29. Welding
  30. '67 Mustang Engine Swap Question
  31. Removing 68 Heater
  32. Fiber Glass Shelby Tail Light Panel
  33. 94 5.0 good for an EFI swap?
  34. Need suggestions for my 351 lower end
  35. Passenger side mirror
  36. I NEED A JOB!!!
  37. Over heating Question.
  38. F(*@&#%$*(K!, broken tap,...front cross member
  39. Best Shop Manual
  40. 347 Stroker build
  41. Anyone without a title in NY State.
  42. 67/68 console
  43. 5 speed
  44. Electric vs. manual choke
  45. 68 Fastback Quarter Panel replacement. What panel do I buy?
  46. 408 Lives!
  47. Can somebody list a pic of
  48. Another "Help me start my engine" Thread
  49. 390 questions.
  50. Trunk Lettering
  51. Inside cab rust removal advice
  52. Where can I get the best FRT wheel bearings?
  53. 64-66: Lower Grill Support Changes / repro vs. orig.
  54. Edelbrock Carb on 302 kickdown linkage
  55. Can't find a 1969 cluster circuit board
  56. Griffin vs. Northern
  57. Vinyl roof repair question
  58. Title Transfer and Registration question.
  59. Power Steering Question
  60. Is this the proper air filter cover for a 6-cyl?
  61. Should I add back up lights?
  62. Hood / Firewall Insulation / FORD lettering
  63. custom floors and sub frame, 69 mach 1
  64. holy bejesus!
  65. How long to wait for interior paint to dry?
  66. 72 mach rim size
  67. On the road again...
  68. Steering adjustment
  69. What Exhaust For A Straight Six ?
  70. Wheels and tires
  71. Motor ID ?
  72. Question on AOD
  73. power door lock actuators
  74. Anyone know if this ground wire really exists
  75. OMG!!! Transformers are real - OT
  76. 351 windsor heads/headlights
  77. T5 Shifter Relocation
  78. i need pics!!
  79. Premium vs Regular Gas
  80. Best $16.00 I've Spent So Far !!!
  81. A little help ...
  82. Sweet burn haha
  83. Manual Brakes To Power Brakes Conversion
  84. WAFFLES this one is for you!!
  85. Restoring my 1966
  86. side exaust on 68 mustang?
  87. Paul Newman Passed Today
  88. 3 point racing harness
  89. Replacing fuel pump... need some pointers please!
  90. Serious Advice to All Members
  91. 47 Fatso
  92. mmmmmwwwwwaaaaahahahahaha!!!!!!! my camshaft is on the way mmmmmmmmwwwwwwwaaaaaaahaha
  93. Cam question
  94. SHE"S RUNNING!!! FINALLY
  95. Need a Photo of Your 68 Convert Trunk Lid
  96. White Powdery Crap Photos
  97. I want to upgrade 1966 from an I6 to a V8. Costs?
  98. When did Ford switch to smaller spark plugs for the 302?
  99. Questionable Insurance Rules
  100. Intake Mani choices for a '70 Ram Air?
  101. Need carb/manif upgrade for stock 302
  102. Found more mystery Ford emblems at that antique store...
  103. Vibration from the rear end at highway speeds
  104. Quick Question on Ignition System
  105. Quick noob question
  106. Spark Plug suggestions please
  107. Re-installing shims after a Shelby drop?
  108. forced induction on classic Stang
  109. Any value
  110. Alternator, generator, voltage regulator
  111. Sequential Led Tail Lights....just installed
  112. What would you notice from a partial rebuild
  113. Brake Booster
  114. Intakes
  115. Installing a Trunck on my 67
  116. Good or bad, not sure.
  117. FINALLY THE DAY HAS COME!
  118. Do I have to change to longer studs with Torq Thrust II
  119. exhaust kit
  120. Some Wedding Photos (56k BEWARE!) Mustang Included.
  121. Car wont start. Starter motor issue.
  122. Aftermarket Stereo
  123. Carb/Intake Choice
  124. 1965 Fastback 4-speed Clutch Linkage
  125. Steeda cable clutch quadrant and cable adjuster
  126. Door warranty tag
  127. Big Ford brake swaps.
  128. EBC Iron Rotors or SSBC Steel Big Bites?
  129. proportioning valve
  130. Spots of White Powdery Crap
  131. Timing Set BEYOND
  132. THE OFFICIAL BB/SB THREAD
  133. Front Cowl Question
  134. What to clean engine and engine compartment with?
  135. ohh crap.
  136. got one trunk drop off done
  137. how do you upgrade distributor
  138. Pertronix installation question
  139. 66 289 Bearing Clearances???
  140. Original Carb
  141. what's the part called?
  142. '69 Torque box question
  143. Mustang is going to get a heavier Motor - Please Advise.
  144. Quarts of Oil
  145. Trunk Weatherstrip
  146. 1970 turn signals not working
  147. Help with water in trunk??
  148. export brace > brake booster
  149. Car starts off in second gear?!?
  150. 289 Engine questions
  151. Window Channel rust?
  152. Here We GO!
  153. workin on my father in laws 66
  154. Classic ROTM voting is open...
  155. backspacing?
  156. Where to find a guage cluster bulb socket
  157. exhaust question
  158. 71 Cougar
  159. my car is JINXED by the mustang gods,...brake fluid soaked floor
  160. M&F Magazine
  161. DIY media blasting question
  162. She is mad at me
  163. 67-68 Center console lights?
  164. Who has Torque Specs
  165. emergency flasher, turn signal questions,...66 vert gt
  166. Voltage Regulator
  167. Sometimes it's....
  168. well this ****es me off
  169. 67 GT Hood Replacement Repair or replace with repo
  170. painting the nooks and crannies.....
  171. Brake Light Out
  172. If you have a Cracked Valve Seal Gasket...
  173. Hurricane Ike flooded my '67 Coupe
  174. selling the 67, whats the best way to get the most out of it.
  175. Where to buy Patch Panels?
  176. heater leaking antifreeze....
  177. Switch?
  178. Avoid Bob's Fords
  179. granada brakes question
  180. to drain or not to drain
  181. 1970 Speedometer cable question.
  182. Quick help please! Engine/trans advice
  183. suspension and steering for a 71
  184. torque converter, starter problems
  185. The hard way to attach rubbers to splash guards
  186. I Got another Car!!
  187. Quick Question?
  188. Nitrous
  189. Thread Prep
  190. Flaming River Rack
  191. 358 vs 408
  192. 1971 Rear Spoiler Location Help
  193. No brake lights, but everything else works
  194. Where is the speedo cable?
  195. Vinyl Top DIY references
  196. Tail, and Brake Lights?
  197. brakes need help.
  198. disk brake questions.
  199. Steel braided P/S hose
  200. Update on the "Twin Turbo 65 Fastback"...(pics)
  201. What could it be??
  202. engine swap
  203. Headlamp wiring trouble
  204. 351 help???
  205. Distributor 351w 1969
  206. Body Question
  207. Re wiring car for a CD Player
  208. Disc Brake booster
  209. Subframe Cost
  210. need new engine
  211. A pic of my new ride and my window sticker!
  212. Taking apart 1965 Mustang door (fixing the lock)
  213. 65 Mustang 200ci T-5 swap on a budget information
  214. Calypso Coral & Grabber stripes
  215. Engine ?????
  216. '65 289 fan and overflow bottle
  217. New cowl
  218. Firewall replacement update
  219. Dash removal
  220. where to start
  221. tunes and tuneups
  222. 460 cid and a ford mustang
  223. few pics and a video :)
  224. Rust spotting...
  225. better engine?
  226. 4 piston SSBC calipers worth the $600 or ?
  227. Will a T-5 suffice with a 302?
  228. strut rod bolts
  229. bad joints
  230. guys with the 65 need your info
  231. Door Window Removal 68 Mustang
  232. 5 speed
  233. Tips!
  234. Rear End Collision Safety: Gas Tank nuts/bolts?
  235. Retro Look Audio
  236. i need help
  237. In need of help
  238. Rear Seats for 65-66
  239. Air Fuel Meter & Wideband O2
  240. Pulled the engine this weekend and...
  241. Question on Lockset
  242. How to test "oil" light
  243. woooo!
  244. Upgrade Front and Rear Suspension on 64.5 mustang
  245. Help with 1966 brake lights
  246. Next 10
  247. 65 Mustang Engine Sounds
  248. Gauges for a Mach 1 -69
  249. T5/Hydraulic clutch and heat question
  250. Need Some Help
