- Transmission rebuilt how many miles for break in?
- Driver Side Suspension
- t5 swap help
- oil dipstick tube stuck in engine :(
- Ignition switch not working ???? Anyone??
- tune carb motor with 4 barrel holley
- Dual intake hood scoop?
- '66 C4 Issues
- Need help with instrument bezel
- 69 trunk lid
- Sway Bar End Links?
- Removing the clutch pedal assembly...
- 65 Manual Steering?
- Still running hot
- 289 engine rebuild or replace.
- 429 cam help!!
- 429 cam help!!
- removing old panel adhesive
- Does This Pitman Arm Look Right?
- car stalls immediately when put into gear/reverse
- Front Suspension Question (Replace UCA/LCA?)
- Inline 6. I just realized something
- Mach I Nasa hood
- to many issues!!
- Inline 6 Carb (and other parts) questions
- 71 Boss
- 1966 Dimmer Switch
- Brake handle return spring, Where does it go?
- Too much power?
- old 9" or newer 8.8?
- windshield replacement
- need rear end part Phoenix az
- Quality quarter panel recommendations for 1971
- Kickdown cable attachment
- Disc Brake ?
- distribution block
- Vacuum module
- Disc Brake Recommendation
- R-134a conversion
- Pre-First Start
- RPM Gauge Issue, Advice?
- AED vs Quick fuel
- 67 deluxe seat backs, best aftermarket?
- hydraulic roller break in
- Late model 5.0 in 1965 Mustang
- Carburator
- needs some ideas on engine and tranny
- 390 from a f-250 is this ok to swap?
- cougar mirror on a mustang?
- Anyone converted 65-66 parking brake handle to pedal??
- engine surge
- 69 Coupe w/ vibrating 289...
- Alternator Upgrade Clarifications
- Another '67 Deluxe door panel question
- 351 stoker combofor a 418?
- Sub-stacks for Autolite 2100?
- Sorry guys, I just couldn't help myself!!!
- Flickering Lights/Ammeter Gauge
- Slap File for Body work?
- AOD input shaft
- 8.8" rear end question
- Wiper holes in cowl..
- Things to do before I ship the car.
- HELP ! New motor won't rev past 2000 rpm
- Electric water pump
- sill plate installation problem
- Rear Parking Brake cable routing at frame
- font for rocker panel stripes
- 6CYL or GT CLONE
- Need some advice/suggestions: 67 cowl area
- Shelby Drop Template
- Single to Duel Exhaust w/ a t5 trans questions
- valves wont adjust
- 05+ mustang wheel to fit 66 mustang
- How much hassle for a tranny swap?
- What would a 69' 429 engine be worth?
- What engine uprades should I go with?
- Fuel tank pressure relief line
- Cowl seal for 71 Mach 1
- some pics from recent car shows
- Wheel Problem
- 68 tach
- Fog Lights Power Source
- Gangster Lean...
- Best restoration book/manual for a 65?
- Who makes a 1973 Mach 1 complete wiring kit?
- fuel sender?
- ebay paypal headache VENT
- 1968 Mustang GT/CS Drum Brakes
- Lincoln rearaxle in '70 coupe?
- Wiper electrical help..
- Very simple restoration Question - 66 Mustang V8
- top loader transmission
- "body" work on Mags?
- Strong Exhaust / Gas Smell in Cab
- Adjustable Strut Rods for a 65?
- what mufflers should I get?
- ANOTHER wheel question...
- Wheel came off!!!
- 1" UCA drop pics
- Heater Core
- Heater Core
- Claysmith Cams??
- Project Super Snake
- Hood locks?
- simple gas cap question
- Koni shocks?
- '66 Mustang: Engine Will Not Crank
- Should I just get new control arms?
- 6 cylinder trans on 289
- Gear shift linkage rattles loudly at high RPMs
- Anyone rid front end of squeaks?
- pink '67 mustang
- anyone running the TCI front end?
- Brake vacuum on a 6 cylinder
- show me your steering wheel
- Straight six 200 performance options
- Engine Electrical Connectors 1966 mustang
- Another Edelbrock 1406 question...making the switch
- Help...Any Two Tone 65 - 68 Coupes?
- gauge cluster ideas
- Master cylinder pushrod grease?
- Spring Spacers
- new front end changed things
- Suspension, steering and spring
- 9x1 1/2 Drum brake parts?
- 1971 429 super cobra jet info needed!!!
- 68 Fender removal
- 347 buildup
- Installing front frame rails on 65 coupe
- seat covers?
- annular vs downleg bs straight leg
- 351C general questions
- Aftermarket fog lights?
- First ride!
- Mustang VIN Stamps
- Getting started on merging the EFI harness into the car
- Engine help
- Exhaust cutouts are here.
- Total Control's fender flaring
- Just received my leaf springs....
- install a console in a non-console code car?
- Price of repairs?
- Yet again the T5 lays gutted.... sigh
- FRAME RAIL ISSUES
- Pics from vintage racing weekend at LimeRock
- Original tilt steering column
- 351 cleveland parts
- Black and White pony interior matches?
- Anyone have improved upper arm shaft pics?
- WTF!! Bird Crap ate through my clear coat!
- edelbrock 1406
- R&Ps
- Another dead electrical system
- 1965 coupe window jamb patch panels
- Body finally primed
- Fog Lights in a 1966
- Car wont Start
- flush brake lines?
- 1967 Deluxe interior door handle question
- Distributor experience
- Mustang got junk in the trunk!
- Firing engine for the first time
- rack and pinion conversion kit
- Thottle return spring on 6 cylinder?
- can anyone tell me how to wire in a start button on my 67 mustang?
- How to tell what spindle I have?
- crane HI-6 :-)
- '67 4 lug
- Most outta 454?
- can i put 04 cobra brakes on a exploder rear
- disc brakes very very soft
- '68 Mustang Console
- What type of sealer to use between shock tower and frame?
- engine gurus
- Thermactor distributor?
- How much is this car worth in todays market
- Water Temp Sender
- I'm seeing red------finally.
- Disc Brake Conversion
- Upgrading to larger sway bar...mounting holes?
- Power Steering on a 67 Mustang.
- Manual 4-wheel disks & hydroboost
- crown vic disc brake swap on 66 mustang
- Intake Manifold Gasket replacement
- front susp. and frame...... in need of help!!
- White Smoke
- Wheels and Ride Height
- tire and rim size.
- need ac help/info for 1966 after market
- Need to install a headliner into a 1989 Convertible
- Ignition Switch 1968 Coupe 289
- ford 9" rear end
- how much is tis worth????
- Rebuilding after crash
- Champion Radiators
- New Grille
- Getting a new crankshaft. Need some wisdom
- ! ROUTE 66 !
- Autolite 1100 Stalling
- Timing Initial and Total
- Time to rebuild carb
- cfm requirements
- 67 coupe, New Suspension (HELP!!)
- inline 6 to v8 swap
- 1972 sheetmetal restoration problem
- Stock 67 Brake Problem
- Need literature on 5.0 build
- door hinge pins!!
- 351 Windsor enigne
- Old school western wheels
- Holley 570 carb tuning getting there :-)
- Removing ignition
- Front disc question
- Keys
- 4 barrel finished off my c4 transmission
- tranny oil change
- How do I remove cap nuts - heater core cable
- decided to plan out an engine build
- what's it called?
- Anyone using the Baer Tracker Outer Tie Rods?
- Hood rust
- Engine Bay Prep.
- whats a c4 worth
- How to get the UCA and LCA off?
- Road trip.. going home
- Repair Help - SAIL PANEL VENTS!
- Do you ever notice different smells from your classic???
- Passenger Vs. Driver
- pedal to floor
- high beam not working
- Back to the classics
- Bought another one! Rusty 66 vert
- Pinched fuel line
- Widest Tire Size???
- Roller block question
- New Owner, First time Poster
- need advice with my fastback
- sway bar bushing lube?
- Ignition Switch Problems
- MSD box and distributor or Quickfuel carb
- New parts!
- Cleveland Build
- Fuel Filter
- Need some help from New Jersey Mustang owners
- Rebuilding shift lever
- Sequential Tail Lights Incandescent
- 1967 tag question
- paint white console or restore it?
- Underdash A/C Hoses
