View Full Version : 5.0 Mustang
  1. wheel hopping
  2. Wiring up T5 after AOD-T5 conv.
  3. 5.0 conversion question
  4. Vaccum Line and coolent lines to TB
  5. 90 mustang AOD trans work on a 98 explorer 4.0L?
  6. Wiring issues
  7. 3rd gear grinding?
  8. can someone help me out?
  9. MOVED: Mustang Hood
  10. Help new to the AOD
  11. Location of fuel lid opener for 86 capri?
  12. Huge wiring problem need help big time
  13. Headlight Adjustment
  14. Clutch install help, never done this before...
  15. dizzy wiring
  16. how do I know if my computer is sending corrective codes?
  17. Stock 10 hole rims?
  18. What's the largest size injector that you can run with a stock computer?
  19. NEED HELP!!!
  20. whats better
  21. chirping coming from tranny ??
  22. vortech supercharger question
  23. gas gauge and speedo not working
  24. Best CAI to get for my 86
  25. Timing Question...
  26. SLR Motorsports Ultimate Performance Chip
  27. bolts to block off heads
  28. Good Heads For My Setup
  29. which valve springs?
  30. how hard is it to rebuild a 302?
  31. Bouncing speedometer
  32. clicking but not startie
  33. clutch/t-5 experts
  34. Help at 4000rpm my car would go...
  35. Bolt broke inside of head
  36. front blinker lense removal
  37. is it worth the money for tfs
  38. What Spark plugs for Afr 165 heads?
  39. MOVED: just got in a front end collision....
  40. Tie rod ends
  41. Smokin' stang
  42. supercharger or turbo?
  43. 88 mustang shaking bad
  44. Steeda Clutch Adjuster Kit
  45. help with tranny
  46. clutch adjustment?
  47. Weekend Warrior
  48. Need more stopping power
  49. Converting everything!!!!!!
  50. fuel pump issue
  51. Mustang 302 AOD Trans is not shifting into OD
  52. Nitrous window switch suggestions
  53. Pony Wheel questions
  54. Is a phenolic spacer really worth any gains? (GT-40)
  55. 1994 5.0 smog and egr
  56. body work help after wreck
  57. tire size?
  58. FourEye Question
  59. Car height/Stance ( Eibach Drag springs & HPM MegabiteJR )
  60. Getting harder to start...... Help
  61. Need new exhaust ?
  62. How to clean Engine
  63. Accufab FPR problem
  64. Need some help here...
  65. hunting idle..map sensor??
  66. Whats wrong with the search?
  67. how to set base timing
  68. fuel injector Q?
  69. is my clutch toast??
  70. what kind of spark plugs
  71. Early 80's mustang motor swap...
  72. sea foam engine treatment?
  73. noob water pump question
  74. Running lean and backfiring
  75. fuel pump question
  76. AODE to T-5 swap question
  77. setting clutch? please hurry!
  78. miss fire ?
  79. Spring and valve Question
  80. back firing thorugh carb
  81. timing
  82. Good aftermarket ignition?
  83. Replaced headgasketsCar wont start
  84. Headers and H-Pipe
  85. no MAF on my 87.. should i convert?
  86. clunk noise while driving
  87. good price on gt40s??
  88. Eletrical PROBLEM NEED HELP!!!
  89. Need help !!!!
  90. I need Rear end Help!
  91. MOVED: Estimated RWHP of my car need input
  92. short tube headers recomendations
  93. Idle Air Control-All Created Equal?
  94. Estimated Gain?
  95. high idle
  96. T-5 TRANNY PROBLEMS
  97. SN95 dizzy on a fox body?
  98. backfiring through intake and losing power
  99. passing emissions
  100. What size nuts are on the Rear Tranny mount
  101. cant search on here
  102. thread size on lug nuts???
  103. HELP! 5.0 won't start
  104. sluggish acceleration after intake swap
  105. Mustang GT trans diffent from regular V8??
  106. Transplant v8 into 4cyl, sorry search is broken :(
  107. Tuning info??
  108. installed intake spacer and egr pipe is too short
  109. jack stands
  110. clutch
  111. Seafoam Q
  112. IM ready to rip my finger nails off for some relief.
  113. sct 4 bank chip
  114. nitrous question
  115. rear end help
  116. American Muscle CAI??
  117. Fuel injectors and fuel pump HELP please!
  118. bucks/rocks itself ???
  119. problem with cylinder #8
  120. subframe rusted out
  121. electircal problem
  122. Opinions on trick flow high port heads?
  123. MOVED: AFTER 7 YEARS OF WANTING I FINALLY GOT MY 5.0
  124. 90 mustang fan clutch
  125. MOVED: which shocks/struts?
  126. AOD driveshaft to T5?
  127. Change computer
  128. MOVED: e or b cam
  129. Cant figure out!!!!
  130. Bigger Flywheel?
  131. breaking in a new clutch
  132. MOVED: racing stripes
  133. 86 Cylinder Heads
  134. axle spline??
  135. hunting idle.
  136. Spindels and Rotors?
  137. cruise control delete?
  138. performance chips
  139. intake manifold
  140. throwout bearing or pilot.?
  141. timing marks
  142. timing???
  143. driveshaft ?
  144. Intake install
  145. amp light on dash
  146. WTF is going on...
  147. vacume help
  148. Draining battery
  149. adjusting the clutch cable, i need help
  150. Adjusting Stock rocker arms
  151. Now i dont think i have>>>>
  152. Smog pump removal
  153. Bad fuel pump?
  154. Do they make
  155. no compression
  156. vibration
  157. Car jerks to either side when I hit a bump
  158. Radiator Annoyance - Mishimoto
  159. A/C ELIMINATOR KIT 85/93 5.0L (FRPP) INSTALL
  160. What do You Think Of this Engine????????????
  161. Found the problem
  162. clutch cable install Q.
  163. RUNNING RICH
  164. gt 40 heads
  165. AOD Blown?
  166. Poly mount install?
  167. msd 6al vs summit's version???
  168. MOVED: Lowered the Monster Truck Car
  169. Got a couple quick questions
  170. Bell housing bolt size
  171. Fuel pressure help
  172. broke main shaft on t5 after h/c/i
  173. MOVED: I just installed PULLEYS + CAI
  174. rear main seal
  175. rear mount battery where do I mount it
  176. Headlights wont stay on!
  177. No Spark!?!?!
  178. Gauge cluster dimmer lights???????
  179. MOVED: WARHORSE!!!
  180. 5.0 Engine
  181. what spark plugs are you guys running?
  182. help: march pulleys installation on 1990 lx
  183. replace smog pump now belt will not fit?
  184. power seat
  185. X-pipe whithout air tube?
  186. radiator trans cooler for oil
  187. Electric Water Pump On Street
  188. Edelbrock Top End Kit
  189. Turbo or supercharger?
  190. MOVED: best exhaust set up's? headers, mid-pipe, cat back.
  191. Lower Springs VS Drag Springs
  192. Swapped Fox rebuild Q's
  193. I Wanna remove the A/C need a BELT SIZE
  194. hesitation - updated
  195. speedometer and odometer stopped?
  196. 7-Up Mustang I'm buying...Help!
  197. HELP
  198. lifter help
  199. MOVED: 5.0 Horsepower??
  200. Dumb Question
  201. Surging idle & bumpy on decel
  202. need some help....
  203. running rich
  204. What size of heads should I go with?
  205. Backfire? Tuneup?
  206. Stalling at startup getting worse
  207. Getting Code 67 with T5 tranny
  208. exhaust
  209. GT40p heads?
  210. shorty header install
  211. F-150 Differential in my car
  212. need a wiring diagram for an 88 mustang eec
  213. MOVED: Rare stang?
  214. Doing brakes..need help
  215. MOVED: What gears should i get?
  216. Stuck Valve/Collapsed Lifter???? PLEASE HELP
  217. tps sensor and explorer TB
  218. NEED HELP ASAP PLEASE HELP
  219. Supercharger Question
  220. Fog light no worky on 82
  221. intake for 5.0
  222. I need help w/ H-Pipe install
  223. my clutch cable just broke !!!!
  224. Rear end noisy, clunk
  225. AOD-T5 swap need 5spd Xmember? Y/N?
  226. Need Help ECU???????
  227. Egg shaped intermediate shaft
  228. breaking up at 2500rpm??
  229. NEED HELP Car=Not Working
  230. Pulled codes got strange results
  231. can harmonic balancer cause rough idle?? revving??
  232. Fuse/relay?
  233. 89 gt quarter panel skirt?
  234. Help!! Urgent!
  235. smash ratio
  236. different timing pointers?
  237. MOVED: slp type exhaust everyone please read!!
  238. Swapping engines?
  239. Stalling problem
  240. Nitous on a stock block.
  241. valve cover question
  242. fron bumper cover swap.
  243. Fan Belt Length Question
  244. Help tuning 1988 5.0 w/ Paxton
  245. Fuel pump stays on.
  246. 1991 LX 5.0 lifters????
  247. mechanical fuel pump question
  248. MOVED: Should i do this trade?
  249. Best Heads For Stock 5.0/Turbo?
  250. MOVED: Aproximate power of bolt on 5.0
