- motor swap?
- Edelbrock RPM vs AFR's
- Would you pay 100-150 dollars for 20-30+hp?
- Surging idle sticky!!!! Here it is!!!
- Squeeking!
- Stock Fuel Pressure @ Idle
- Getting some explorer heads but don't which ones?
- front struts
- Injector Size? How to tell?
- 1 more ? about oil drain plugs
- Can A/C be istalled . Aftermarket?
- fan controllers
- 302 to 306 swap
- 92 mustang, no overdrive
- h-pipe
- Will my current mods work with this short block?
- Fiberglass hatch help
- Foxbody Frame Pt. II
- new car
- Initial Running/Idling Issues
- DEER!!!!!!
- Serentine belt squeak
- Central Cali Meet!
- HELP! Fuel tank leaking....
- 89 stang o2 wiring ???'s
- update!!! new parts coming in!!! pics!
- motor mount
- 1994 GT question
- gains
- FRPP A/C Eliminator Kit...
- Altenator Instalation
- help with brakes
- Cars making alot of weird noises
- MOVED: Nitrous Or Supercharger
- HEADS Q ?
- MOVED: 351W Engine Factory
- sick of pictuers?
- AUTO TRANS is driving me INSANE!
- suspension woes?
- New motor INSTALLED
- 1984 5.0
- rocker arm ratio
- Rockers and pushrods !!
- having acceleration problems
- Electric fan question
- A little sound clipy clip
- Tunning the headers
- BBK valve covers.....
- connecting a/c
- backfiring in 3rd and shakey
- Gt-40 crate engine
- Can someone get me a pic of,....
- oil system
- curious- O2 sensors & clutch assy ?
- UPDATE: STUTTERING PROBLEM
- torque boxes
- Anti-Lock Brake Light
- 88 Cov. 1/4 windows are loose.
- Newb ques...
- Passenger side door lock not working..
- Really had some fun today with the new gears!!! I'm not so dissapointed anymore...
- AFR 165 or 185?
- jammed door
- Best cam for my car
- Steering squeek
- stock rotor size
- wont start
- Cam plug oil leak - EAK!
- Venom
- Touch Accelerator Pedal
- smokey mountian trip
- valve covers no workie.....
- free space?
- Interior
- Determining the Differential you have?
- Dome Pistons
- center caps
- slotted or not slotted rotors
- 84 smoked head lights?
- automatic trans
- new Pics of my car!!
- good deal?
- EGR Issue, CEL Code 332
- Richmond or Ford Racing Gears?
- MOVED: racing an audi
- 302 Question
- Roller rockers ??
- longtubes or shorties?!?!
- MOVED: Cold fusion nitrous kit are they good?
- New Intake and Valve Covers!
- Cheap port
- How well will this cam work for my setup.
- can u swap 347 cam and lifters to a 306?
- Question
- clutch cable adjuster
- GT-40 install help
- nasty door panel pockets
- Stock gears
- best aftermarket parts to get?
- MOVED: what nitrous kits are the best
- MOVED: nitrous
- 95 cobra(what are the differences..)
- My first ride with the 3.90s!!!
- YOUR ADVICE!
- SFI Question..... Please Help
- 83 door handle broke HELP!
- engine suggestions
- Quick ? What are Valve Cover Bolts Torqued To?
- Adjust pressure !
- GoodMark steel hoods
- people in California...
- fiberglass hoods or bumers yay?...or nay?
- why is it
- how do i....
- quick dumb ques....
- where did you get that batt relocation at?
- need info regarding fuel pump
- The official FIX MY DAMNED IDLE THREAD!!!!
- Symtoms of bad fuel pump?
- Oil drain plug washer?
- Need some advice
- HP gain from camshaft?
- how to take the LX spoiler off
- More Traction... smoother ride... free!!!!!
- Help me please!!!!
- Which Diff? 8.8 or 7.5
- pic needed spark wire routing w/ moroso
- Installed 180 Thermostat - Have Problems Now
- HELP! Hatch Lifter problem
- Keep Fouling Plug....Need your thoughts
- Orange County Gears Shop
- 88 Coupe 302 won't start
- Which Heads??????????
- BLOCK HELP? 331 Stroker
- New Engine!!
- Haynes: Cooling Change?
- I wanna learn
- can someone calculate my compression..
- 1995 5.0 gt hp estimate
- Big smokey burnouts
- Maximum Motorsports Adj. Control Arms
- need help pulling my 5.0
- How much is it worth
- Narrowing Down My Stutter Problem
- MOVED: which supercharger?
- header question
- need help with brakes
- one last time..?
- Wheels
- I'm excited for tomorrow and I'm wondering what my next mod should be!
- afr 165
- Opinion needed.
- Bang for the buck HP!!!
- C4 Trans
- 800 $
- Put stock 5.0 In HELP
- need carpet! come in here addermk!!!
- power steering rack
- suspension......
- WaCkY IdLe
- Kenne Bell 5.0
- Misfire, Cold Idle, and Gear Questions
- How much should I expect to pay for a car?
- Flaming River stuff........
- rust repair
- 95 cobr ,blows haed gaskets?
- 85 mustang help
- im tired of looking for one
- Cap rotor plugs and wires
- need some help
- Best Exhaust from the Cats Back
- emblems.
- Where to get a 89-93 mustang dyno tuned and chip burnt
- Injectors/AC
- airbag light, no horn and no c/c
- 86????? what the deal
- Cruise control surges.
- Where do you find
- MOVED: whats the point of buying a v6 mustang?
- Where can i find?
- cleaned engine now probs
- weight reduction
- looking for aftermarket gauge clusters for 95 gt!
- BBK-SSI intake
- transmission synchronizer
- Stock Weight?
- Went to track last night!-See video 5.0 HP
- installing headers!!
- box intake
- free engine upgrade
- any good tech articles...??
- idle temp?
- Spedometer out of control?
- ac removal
- Question about Dual alternators.
- It all starts Tom.
- A/C - Vent/Defroster door moves during acceleration
- Fuel question
- Convertible top relay location
- who's got Magnaflow-X pipe-shorties Headers?
- Pullies?
- power loss
- Fuel pump question
- summit heads
- 20hp chip (resistor)
- Dynamic Racing Products
- MOVED: Speedtrapped
- MOVED: ordering a vortech s-trim
- How do I install GT trim on an LX?
- seats
- camber kits
- What is the Best sounding mufflers,would like everybodys opinion
- MOVED: holy sh!t
- In the market for a 5.0, just a question or two...
- Interior lights wont work
- my car slugs then backfires...why?
- sb ford cam question
- got a corvette owner to say wow your car has balls
- TPS problem need some help
- Stalling in Neutral??
- summit battery kits.
- checking engine codes
- should I buy it
- Guzzling noise???
- too low in the rear!!
- Rough idle and hesitation
- Stock Gas Gauge
- car is draing batteries like crazy
- ANY HAVE THE SUMMIT SPORT SEATS IN THERE 5.0
- quarter window moldings
- 4.30's
- power locks wont work
- battery relocation
- gas tank
- Video works now, check it out!
- Anybody Have These?
- 2:73 vs 3:73's 1 gear?
- Good deal on 302?
- seat wont stay up?
- mustang week
- Sound Clips X vs H pipe
- MA Laws Wider Rear tires
- short block 302
- Louder?
- aftermarket hood
- 5.0 short block
- more fuel?
- lets hear your car history
- Car won't start
- Upper Strut Bushing
