- idle....
- MOVED: kinda hard to admit this,this car may be headed to my stable
- Smoke/Steam
- Factory Tach...or Autometer...Who is accurate?
- Is this Balancer Loose?? *pics*
- SN95 GUYS!!!!!NEED HELP FAST!!!!!!!!!!!!!!!
- Convertible replace help.
- Sunroof part needed ASAP LEAKINGGG!
- Paint My Pony Rims
- tire/wheel size
- found out why my battery kept dieing
- F***
- Driver side sitting low
- headlights
- Help me ditch the swaybar
- how much ?
- E7 head question?
- heads.....
- How do you find out rear end Ratio?
- AODE question
- Supercharger Breather System..Take 10
- Mustang Meet and Greet
- kennebell supercharger
- Aftermarket Control Arms
- What kind of headers to get?
- Rear end question
- fuel problems need help
- teach me about nitrous
- 95 mustang overheating
- Freaky Temp Gauge
- dash lights
- Manual V Electric Pump
- Instead of an engine swap, how about...
- I done did it now...
- 94 gt tuning help
- Fuel Pump Relay
- Posted in SVO but maybe someone here can help
- would these tires fit??
- power pipes
- Exhaust leak
- Look what boost did for me :(
- fibergalss or other hatch
- custom cam
- where can i find...
- cant start the car with key
- anyone have any pictues of the new one piece headlights
- Stuck Starter Relay???
- ? about valve covers
- Turbo and CR
- radio/heatandair relocation kit?
- MIL questions
- went to the candy store today
- upgrading brakes
- loss of power after fixing exaust leak?
- stock cat-back with o/r h
- air fuel ratio gauge ???
- lowering sping??
- Watt's Link
- time for a new motor..what to buy?
- MSD clickity click?
- Info please?
- Submit Your Custom Cam Specs
- Flowmaster question.
- Cam
- 302 question
- License plate lights?
- Motor noise...
- Windsor question
- Does anyone have a guide to removing emissions?
- timing pointer
- what do you guys think?
- drive shaft
- fuel guage doen't work. stuck on full
- bullitt wheels
- Dicount Performance Parts
- looking at fuel pressure regulators
- Oil gauge
- not working dash indicator lights
- 1995 Cobra no spark
- blue oval industries
- What Battery are you running?
- quick question about exhaust
- heads question
- Sensor On Right Hand Of Throttle Body???
- anyone have a vortech v2-sq trim clip?
- vacuum line frustration
- Afr's are on!
- overheating coolant problem!
- 1,200 RPM stall
- pulling motor and trany on 93 to put tranny in 89 ranger,lol
- engine block
- Street or Track Heat TFS
- hood pin question
- KYB AGX adjustments
- Power steering pump...
- Check Engine Light
- VALVE TRAIN
- light weight damper?
- GT40 Tubular on a 94 GT?
- A/C
- March A/C delete idler pulley kit - Im confused
- What flowmaster mufflers are these?
- mass air question
- noob question.. suspension
- New lifters with new cam?
- another question about the rear end
- I NEED MAJOR HELP!!! ASAP
- my mustang
- 460 big block
- gears?
- 3.90s
- Unpleasant surprise
- Smog pump kit - Gain or lose hp?
- good place to get primer?
- the dreaded muffler question
- PSI Problem
- tires for draglites 15X3 1/2 ???
- Clutch
- First 5.0
- not ur average gear question...
- Symptoms
- Pulled some codes....
- Don't Know what is next?! HELP!!
- Tuning Problem!!! YOU BETTER KNOW UR STUFF
- windshield trim??
- HELP! Pulling engine
- front sway bar question! help!
- Saleen Bezels
- valve clatter
- Daily Driver Issues! Help
- exhaust
- blah, looks like no ac
- Finally got my ac working properly
- oil pressure?
- need help building a 10 second fox
- Engine Coolant Temperature sensor (ECT) bypass?
- temperature gauge question
- New section, EVERYONE please read!!!
- MagnaFlow Cat back with/without headers?
- GT40 explorer heads, what years?
- aod shift question important
- NEW MOTOR....questions about parts
- intake manifold?'s
- AIR CONDITIONER HELP PLEASE
- some more head questions
- New Plan.. Details inside
- 5.0 swap questions
- do i have 3.08s?
- Need some serious Motor Techs
- question on trouble codes
- Will a T-5 bolt up to a late 60's early 70's 302?
- Backfired this morning!?!
- 1991 mustang 5.0 questions
- neutral pressure switch (NPS)
- stupid question
- Autometer Ultra Lites...
- Pics of new project.....85 SSP Coupe
- 3" tailpipes
- oil cooler + filter re-locator??
- seat belts are stuck/jammed
- Only real mod this yr...can you figure it out??
- Clutch adjustment?
- Problem with cooling system.
- ecu compatibility with T5 swap?
- engine question
- NO POWER
- speedo help
- ignition system what is better analog or digital ?
- '89 5.0 Auto to Manual Swap
- how much time off with gears?
- Intake cleaner and problems with idle now
- turning flywheel
- header bolts keep coming loose
- what camshaft?
- Nitrous
- Heads are back!...from Thumper
- Beeping help 1990 gt
- 9,000 RPM 5.0L possbile?
- radio dosnt work
- Pushrod legnth
- I need some major help with my car guys.
- 302
- Finally i don't have to smell gas
- gromit?
- sn95 oil pan question
- Mileage question
- Next Step- Newbie More Power
- havent driven powerful car yet, advice?(new pics!)
- car won't start
- Need help..what wires to connect to make the horn work?
- Started my Head Swap
- Question on BBK fuel pump Install?
- Got Scared
- pulled codes... again
- 331 OR 347
- weird noise
- dragstrip control arms
- 86 owners (ANYONE) i need help (now with some pics)
- Problems with Typhoon lower intake
- 289/302 question
- engine fan
- install75mm mas onto cold air kit
- dent removal
- my car is done finally
- exhaust/header question
- supercharger 5.0
- front wheel bearing on 95 gt
- Launch and 60ft.
- How much to sell for?
- mechanical problems. wasup >.<
- How do I bypass my o2 sensors?
- Fan Clutch Going South?
- ALT?
- What mod do i need to do?
- Please help...
- my soon to be setup (maybe)
- detroit piston tickets. Not tech, i know
- 94 GT cooling problem
- finished my pretty paint job
- come on guys
- 94-99 came stock with 31splines?
- exhaust for aode
- max lift?
- balancer/flywheel
- Can I paint my interior with engine paint?
- K- Member
- 89 LX 5-speed; 56mph @ 1500 rpm = 3.73?
- wirring
- AOD to T-5
- what does it take
- Lock Wire Head Gasket Question
- Steering Wheel Hub Removal?
- Anyone no were i can get door mouldings
- how much hp?????
- doing a wheelie???
- dome light removal
- new toys are in afr's 165
- How to lose weight for my DD
- NO POWER!!!!
- Tire Inflation Question??????
- intake ?
- Squeaky Sunroof
- Carb or EFI
- Door Hinges on a 93
- heres some videos at the track and of horse play
- fan hitting shroud, engine sitting to low
- launching off the line
- Need help with my 85 4V HO
- REBUILD ECM
- gear break in question
