- clutch cable?
- build up!!!!!!
- Clutch break in
- New tach, opinions?
- 8.8 rearend f-150 vs. mustang
- relocating a/c controls to ashtray slot
- problem with door lock & window
- door rattle
- thermastat
- vacuum hose diagram any1?
- Smog pump deletion
- mustang brake upgrade
- I just put about 120 HP in my engine...WHY IS IT NOT RUNNING???
- Window went down won't come up
- Intake+Cam vs. Heads
- COME VOTE!!!!
- COME VOTE!!!
- Speed density idle problems
- mufflers
- 5.0 vs 302
- Belt Broke
- Brick wall higher rpms
- Driveshafts, looking for replacment...
- how will this cam for my combo?
- 94-95 cobra Motor TQ
- Next Mod
- cluncking in rear end after swap
- lookin at a 5.0......
- Just a ??????
- Pro 5.0 vs. Steeda Tri-Ax shifters
- what else should i do?
- driveshaft lenght
- bit of a trans prob.
- Frustrated steering
- Hood pins are in.
- 5 lug rear disc????
- Vacuum question 1990 GT
- Injectors
- kickdown cable issue
- SMOG EQUIPMENT REMOVAL/ COMPUTER CODES
- crankshaft problems
- Lincoln Mark VIII fan
- How do i tell what gears i have ?
- selling my heads
- first car
- question about installing sumps
- 87-93 Instrument Cluster removal
- water prob
- need help with tire size
- what are the widest tires i can get for pony wheels?
- gt body pieces for lx
- Help diagnosing vacuum problem
- Traction
- BOV Question
- shift knob is stripped
- 1969 mustang needs help fast
- Who's using manual steering?
- Short block dilemma...
- installation of bbk off road h pipe
- gt-40/explorer intake question?
- horn sticks on 88GT
- First Mods to 5.0's
- 5 Lug conv.
- custom cam?
- EGR—Check Engine Light
- Flip Chip
- Bad rear brakes... vibration?
- Exhaust Sound Clips
- 94 GT upper and lower intake
- Should I replace my AOD with a C4?
- Head porting question
- Bogging middle rpms
- 5.0 EXPERTS NEEDED
- 95 AODE PROBELMS
- Holes in air box?
- need some help with door trim
- how many people like the sound of the X-pipe?
- Headers
- noisy or not!!!!!!!???????
- Good battery relocation kit?
- Front fans not working on dash
- Engine won't start
- the 82 bites me again
- t5 swap to c4
- Gears
- Home Made CAI
- General gauge question...
- Need to know RPM/mph for AOD
- Gas Gauge
- TEMP ?
- 347 stoker kit...need help with choosing
- Best ignition components?
- Oil
- 4 banger ins. cluster (tach importantly) on a gt
- does lens cleaner work or better to buy new
- IDENTICAL PULLEYS???
- might be a good sticky
- 4.30's....Im considering....
- Intake gasket leaks
- bbk headers
- Which BELT works for bypassing components
- quadshocks still needed?
- Torque Converter Question
- new clutch
- Is a tranny swap worth it?
- Cleaning MAF
- transmission issues
- magnapacks
- Whinning noise from engine?
- Surging and rough idle.
- Electrical System Problems
- C&L maf causing idle issues with BBK CAI
- quad shock
- trans. ?
- Blank Canvas '94 GT
- rear end twist?
- OBDll won't work!! Arghh
- NEW CONTEST!!!
- rims and tires
- getting 1.7's-what brand?
- torque boxes
- 5.0 rebuild kits
- Pulley kit ?
- Hard to start first time
- 347 Stroker ?'s
- info on 83 mustang GT
- how much gain? guesses
- insurance
- Serpentine Belt Bypass Question
- how much gain?
- strut tower brace
- FRPP A/C Delete kit (Need pic of install)
- Engine year???
- hp question
- Air Silencer (93 GT)
- 94 ecu
- Tallest and Widest Tire on......
- oil pressure low?
- BBK SSI Intake
- Building an interstate killer
- aluminum pistons
- transmisson coolant lines only for AOD?
- weird pulling?
- 347 Qs
- Gauges
- 5.0 stuff...
- header install
- cam question
- guage cluster, or sending unit
- MAF
- re wiring fog lights
- Can't rev past 3k
- Underdrive Pulleys....?
- super charger
- head and cam combo
- 5.0 HO Specs
- what size injectors?
- ordering a new motor
- t5 trans upgrade
- t5 trans upgrade
- Low Coolant?
- another idle ??????
- Elec. Short? Keep Blowing Instrument Panel Lights
- new engine
- Car has lost power.
- heat problem
- Amp light during acceleration
- im a dumby lol
- Question about fox bodied mustangs/GT (87-93)
- Brad Pitt's brother Stu
- drove my car a few days ago
- 4 speed???!?!??!?!?!
- Quick Question BOLT PATTERN
- Pedestal mounted 1.7's
- What numbers and times can I acheive by bolt ons?
- Hey everyone
- My night of exhaust work.
- clutch problems
- AOD Tranny Problem Need Help B4 Tomorrow
- ANOTHER IDLE PROBLEM!!!HELP
- fan messing up a/c??
- JUST ORDERED HEADERS AND AN OFFROAD H!!!
- Just some new pics of the Installs
- Timing adjustment
- Swap 1993 Auto to a Manual? HELP!
- H-pipe if I have flows?
- Engine Vacuum
- o2 sensors, and trannys, and tail lights...oh my
- street/strip racing seat
- gears
- Gear ?
- what gear should i get
- 392 or 408?? stoker kits
- stupid question
- Look at this list of mods and tell me what you think
- new heads
- O/R H pipe and headers
- Vibration at 3000 RPM
- Cut off the Top cats???
- what shifter should I go with????
- PCV - what the fark?
- 95 3.8 to 5.0 swap starting TODAY! 7-28-05 any advice?
- need help changing to hyd cluch
- Plans for the new engine!
- A/F Guage showing lean??!!
- King Cobra Clutch includes throw-out bearing?
- cam????
- intake spacer
- differential prob?
- Does Anyone have dumps on their 5.0?
- VALVE COVER CLEARANCE
- Should I port my heads? which cam?
- Intake Decision!
- tranmission
- '93 LX steering loose??
- the ticking nosie in higher rpm
- Time for a new clutch
- head gasket???
- Carb Jetting
- '87 5.0 rear end
- done some modding
- upper radiator hose leak
- tbody adapter
- revving
- 89 5.0
- Performance Chips
- how much horses....
- Setting the mother ****en TPS!
- Porting and Polishing
- GT-40 Intake
- Stock Injectors
- programmable engine management system
- Cold air intake?
- 93 saleen 17 inch rims
- ETA
- crate engine..
- vibration
- MASS AIR
- oil for my cobra
- gear questions
- thinking of trading my coupe body
- wondering which fuel pump to upgrade to
- unspent fuel diaphram??
- 351 in a pasture ???
- Severe Engine trouble
- gt-40 performance questions for new member
- Anyone have a kenne bell.
- HELP! Intake squeak????
- what supercharger should i go with
- strut tower bar made to fit a trickflow intake?
