PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 [292] 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Injectors interchangible?
  2. Starter
  3. Whats the problem?
  4. hood problem.
  5. transmissions..?
  6. installing a AC Delete Kit
  7. Which clutch do I have?
  8. 91 LX 5.0 Convertable
  9. got a leak...
  10. 88 5.0
  11. Turbo?
  12. underside of cobra intake?
  13. big problem help!!
  14. Interesting problem....
  15. SD over MAF 1/4 times
  16. alignment and header gasket
  17. C4 swap
  18. 94 exhaust and other crap.
  19. good combination
  20. rebuild kit reccomendations
  21. 351 FI stang project
  22. Christmas came early......what size injectors?
  23. fixing heater core
  24. The other day I.... BLEW IT UP!
  25. chip for my 91 5.0
  26. exhaust ideas?!!?!!?!?
  27. Spark Plug Recomendation
  28. loose rocker arm??
  29. Timing adjust ment?
  30. weight reduction
  31. what gears?
  32. 88 mustang wheel and tire clearance
  33. Supercharging...
  34. ceramics
  35. header bolt!!!!!!!!!!!!!!!!!?????
  36. Spark problem
  37. rebuild time
  38. mass air meter
  39. 351 swap, HELP!!!
  40. H pipe and muffler fitting question
  41. Eibach Drag Launch Springs Kit
  42. favorite hoods on fox.
  43. Snow Performance Methanol Injection
  44. 95 fuel pump.
  45. Cleaning pcv screen?
  46. gearing up
  47. rust???
  48. thinking of new cam
  49. OIL PROBS
  50. cooling bad
  51. Quick rocker question
  52. car seems like its not making power
  53. your exhaust setups
  54. Transgo Shift Kit
  55. what shoul i expect?
  56. Tire's fitting?
  57. Throttle Body
  58. bad crank vibration
  59. need HELP please new tfi and no difference
  60. Ford Motorsport 65mm Throttle Body?
  61. stock coupes 1/4 times
  62. Central Coast Mustang 327, 342?
  63. Rebuild or New Motor?
  64. 5.0 Bolt on Performance
  65. Changed IAC. Idles high
  66. 347 vs 408 or 427
  67. 5.8 heads on a 5.0
  68. Whos Running a High Compression 5.0
  69. '95 Mustang GT Engine Problem
  70. Start the car... immediately it revs
  71. Interior Question.
  72. Third gear problems
  73. Cobra R radiator.........
  74. came across a deal!
  75. engine block
  76. 95 Mustang Gt
  77. anyone run a fox in AUTOCROSS
  78. h pipe problem
  79. SLP Loudmouth
  80. Sound clips or recomendations
  81. 93 5.0 BOGGING DOWN AT FULL THROTTLE
  82. Taylor Wire Looms
  83. Engine missing. HELP PLEASE!!!!!!
  84. rocker arms are a nightmare!
  85. Adjustable Clutch Cable HELP!!!!
  86. t/bird s/c ?
  87. convertible quarter windows
  88. Putting in a 351W
  89. Clutch
  90. Sticking Idle
  91. 5.0 Skipping/ MAF Conversion problems
  92. Installing E-303?
  93. adjusting clutch bands on a c-4
  94. h pipe
  95. whats going on with my 5.0
  96. How good will these Drag Lites Fit?
  97. CHP vs DSS shortblock
  98. Lowering Springs
  99. Mass Air Conversion?
  100. Runs like poop on hot days!
  101. What kind of springs ??
  102. installation successful
  103. radical cam...jumpy idle?
  104. Engine oil leak
  105. Decision assistance
  106. 4.6 or 5.0 for Performance
  107. manual trans/shifter Q's
  108. O/R H-pipe and glasspacks?
  109. Engine Problem
  110. New gauges cause dead battery?
  111. Mini Starter
  112. New mufflers need some help,
  113. HELP FUEL PROB!!!!! PLEASE!
  114. $700 for used gt-40 heads?
  115. getting rocker arms today.
  116. Amateur Eng Q
  117. saleen rims
  118. How long can it sit?
  119. fuel filter?
  120. EGR?
  121. Head gasket question
  122. Custom grind cam
  123. twister
  124. 94-98 GT or Cobra speedometer on a 92 GT
  125. power windows/ vert question
  126. '86 5.0L upper vs '88 5.0L upper questions???
  127. bypassing ac compressor
  128. Exhaust Leak
  129. speed density problem?
  130. Starter keeps cranking with NO KEYS IN CAR!
  131. reseting ECU
  132. Fuel pressure too high?
  133. Air/Fuel ration guage install
  134. smog pump question
  135. got my longtubes on!!!!!!!!!
  136. spark plug gap
  137. Blower in a Fox...
  138. High rpm missing
  139. building a 331
  140. Need help hooking up!!!
  141. Problem need alittle help
  142. speed density cam
  143. Leaking Coolant
  144. Transmission Slipping
  145. Begin fixing things tomorrow
  146. FI 351
  147. fire!!!!!!!
  148. 429 in a coupe???????
  149. lost power?
  150. headers!!!!
  151. motor mount instal?
  152. Fuel Pressure Gauge Install?
  153. 460 in a foxbody?
  154. 302 to a 306 what involved?
  155. stroking it.
  156. big issue w/ clutch
  157. headers- how about intalling??
  158. 1 wire 130AMP Alt
  159. MSD 6A ignition install
  160. what would u say MPG on a 89 GT is?
  161. Overheats,loss of power, then dies.
  162. Edelbrock performs?
  163. no power.. then power
  164. Bought a 86 GT today
  165. transmission temp gauges
  166. Paint for the mirrors and window frame?
  167. Relay/Fuel pump problem
  168. Bosch Spark Plugs Are Crap!!!
  169. What Radiator
  170. Speedo Cable
  171. Coolant leaking out of header
  172. need vacume lines schematics
  173. long tubes- stocked 5.0??
  174. best short shifter
  175. my mustang lost some weight this morning
  176. a few problems listed--1988gt
  177. engine diffrences
  178. 3.8L VS. 5.0
  179. 94 Mustang Exhaust
  180. new exhaust on a cfi engine????
  181. Mods begin"exhaust"
  182. 1994 GT Vert Need opinions
  183. vapor locking?
  184. gears: how much of a difference?
  185. question about ohsoquik's battery relocation sticky
  186. Coolant Leaking From Tb
  187. Gears are in woohoo
  188. Steeda pentar 17 x 8.5 wheels
  189. temperature question
  190. roller rockers
  191. got a problem
  192. what happened to these intakes
  193. what plugs?
  194. How long will fuel pump last if I boost pressure?
  195. Wheel solutions
  196. Running warm
  197. Adjustable Clutch Cable HELP!!!!!!!!!!!!!!
  198. ANY POINTERS ON PAINTING THE FOXBODY??
  199. Signs of a fuel filter going out?
  200. Hurst shifter / Steeda handle
  201. ooh no!!! no power
  202. throttle body
  203. H/C/I question
  204. not sure
  205. whats a good price for a transmission?
  206. Looking for info on cams, & intake
  207. gages problem
  208. new alternator
  209. Thermostat Question
  210. 86 stock horsepower?
  211. what ratio do i have?
  212. info on tubular front end for a fox
  213. check engine light on and off?
  214. "squeeking" sound
  215. 89 mustang timing?
  216. toke a/c out
  217. Way to visually tell 5.0 motors apart
  218. quater window install
  219. 2 in 1
  220. Atlanta Area Transmission Shops Anyone?
  221. B303 cam?
  222. Short throw shifter
  223. fox body 5.0 in SN95
  224. upr vs bbk
  225. What should i do with my money
  226. Vacuum line location ?s
  227. Old Parts...
  228. Cold Air Intake for Carb'd 85
  229. New Gears
  230. good 351W motor mounts?
  231. timing chain cover
  232. 94-95 cobra's
  233. 25th Anniversary Gold Turbine Rims?
  234. '90 5.0 Engine slows to a stop
  235. Advice on auto transmission problem please!
  236. drag lites and lug bolts
  237. oil pan gasket walked out
  238. Fuel Pressure Regulator
  239. Largest tire for ford pony wheels
  240. What do you guys think I should do??
  241. 5.0 header questions
  242. bypass hose leaking
  243. MAF Conversion problems!
  244. Baltimore Restoration
  245. Typhoon or Cobra manifold?
  246. 3G alternator
  247. 5.0 Questions
  248. 90-93 Mustang 5.0 General questions..really want to buy one!
  249. Roundman
  250. Dies After 1/2 throttle????
