- car runs fine. saw 02's unplugged...
- Went to the track!
- Oil Pressure Gauge Question - Problems??
- seat covers
- running rough
- Aerochambers
- 95 Cobra Intake Spacer
- Would it be worth...
- 55mm to a 70mm Mass air meter
- 5.0 in a 65-70?
- TIMING ???????????????????
- 1986 Interior question
- Loud Clicking Sound From CAI
- Cobra seats?
- HAD TO UNPLUG O2'S AGAIN WHAT THE*@*@!
- high rpm hesitation...need help
- Still Rich
- SEAT CHANGE
- 5 Lug to 4 Lug Change
- flowmasters
- took some pics
- would this make 400+hp?
- long tueb headers for AOD
- wiring harness question
- C-4 (daily driver) or (strip)
- AOD Upgrade Question
- Explorer Intake= Cobra Intake?
- weird sound from the rear???
- alright who knows setup for 93-95 starters good?
- oil pressure not stable..
- turning radius
- gauge install
- hood scoop for air filter
- short belts???
- Stock Acceleration???
- MAC Headers, help!!!
- will an automatic computer work with a manual tranny
- more about my starter problems. its long
- mechanical vibration
- how much E.T are pulleys worth
- Shaker or ???
- question about rev-limiters
- Roush wing
- power steering?
- my 83
- Transmission...HELP
- ROUNDMAN'S NEW ENGINE IS HERE!!!
- BAD milage
- will rear sump pan fit in a 68 stang?
- 3.73 install
- will an 88 T5 work in 84 5liter?
- Speedometer problem
- i have a question
- what else do I need?
- Header help
- GOT NEW TIRES ARE THEY ANY GOOD???
- 160 mph cluster
- is this the smog canister?
- help..idle problems
- whoever done my exhaust should be beat
- 95 mustang GT vs 98 honda civic.
- These Good Exhaust For Mustang 5.0 GT?
- Non catted H-pipes mess up your computer and idle????????
- what exactly is proper way to adjust/correct the idle
- getting a 5.0 Notch - what upgrades?
- engine swap
- Engine swap
- anybody?
- remove oil from windshield
- Can i put roller rockers on my stock engine?
- i have a question
- Question
- roller rockers, how loud?
- Cheap Drag wheels?!?
- aod acting funny
- Hissing Sound?
- 95 mustang gt vs 94 sho
- Will it hold or not??
- changing exhaust time to brag what you have
- tire size
- charge problem
- oil pressure...cont.
- cowl guage pod?
- Need an A9L
- Changing brake pads are PITA!!!!!! on a 95 GT
- o2 sensors code number 41
- aluminum flywheel problems
- autolites gap?
- neutral safety switch keep car from running
- loss of power then....CEL came on
- UPR shifter vs. the pro 5.0
- IAT resistance
- Changed plugs, cap and rotor and lost power
- powder coated rims
- any one live in northern va
- horn
- Will this end my tossing of alt. belt?
- Alternator
- Questions Questions Questions
- gauge cluster
- max miallage on a 5.0?
- MSD rotor and cap
- Saleen vs. GT
- AFR's for S trim
- cobra intake
- Explorer engine??
- 5 Lug Conversion for 86 Stang
- will a 65/70 MM throttle boddie
- SO WHATS THE DEAL WITH SHIFTERS?
- 351w vs. SC 302
- LAKEWOOD TRACTION BARS
- Inner Fender Aprons
- Stock Exhaust Diameter?
- Cheap 5 Lug Conversion
- 351w roller block
- Anyoen have this fan?!?!!!
- Holley SysteMAX II any 1 ever used
- mustang is popping
- timming giving power up top...
- run the codes and now need help
- Good Info / Bad Info!
- RUNNING LEAN HELP!
- take off too much air silencer?
- replacing starter
- Pushrod length?
- ignition wires
- injector size
- New Project - The Shelby Clone
- bucking on cold starts
- Problem with my voltage
- Clean MAF
- How do you clean 02 sensors
- Convertible Top Care
- so now the starter went out
- 3.73's are IN!!!
- so is this the air silencer??
- timing
- charging problems help please
- Inhaling Nitrous Oxide
- hmmmm...how much?
- Car slowly shows its power lol
- What next?
- will 18's fit ?
- emissions, inspection questions
- Hey everbody- could this be the idle cure.
- thumper heads
- need advice to get my car to idle.
- FUEL PUMP QUESTION
- whats the difference...heres the specs.
- trick flow intake
- Engine codes
- What were the names of additives??
- Question about hood pins...
- Quick n easy speedo question.
- gears
- getting b-303 to idle good?
- EXHAUST question!!!!!!!!!!
- What car would have a smaller crank pulley for my 351w?
- o2 sensor harness. someone help please
- afr heads?
- accel cap and rotor
- Heads? Which ones with this setup???
- engine conversion quistion
- NEW BFGs....
- PCV valve
- heres some Pics of my car smokin the tires and cruzin
- Radio Harness problems....
- Which Flowmaster???
- A/C delete
- new 5.0
- Hanging idle
- Long Tubes and Eibach's Spring PRO Kit
- how much for tranny?
- what kind of adhesive???
- whats wrong wiht clucth??
- 4 bangers
- heads,headers,intake,cam?????
- smog pump
- trick flow kit
- slp loudmouth
- torquing flywheel....
- 90/10's or 70/30's for street.
- time to replace serpentine belt and bypass smog pump
- Got everything for rearend! ( Pic )
- running like its first started...rich
- cams and smog....
- Sig
- Equal Length Headers Easy to install?
- bassani LTs + prochamber
- BAD o2 sensors
- ignition questions
- Random Hard starts
- CAR HESITATES
- UPDATES, and a question For those who have switched to CARB.- How much did your economy decrease?
- 95 GT Temp gauge mph rpm gauges not working right?????
- 95 GT with a hanging idle problem
- Engine Temperature
- tappets?
- which codes do i worry about?
- Do I need EGR on 5.0L EFI...Drawbacks to taking out.
- what is this sensor for?
- Roush Wing?
- HP Question?
- Open headers, open H pipe, etc...
- what should i do next
- cams...
- Just curious
- CAI make car sound different?
- Question regurading engine size
- ok so i went and bought a code reader
- Air silencer in 88
- Rack and Pinion
- Got my Motor all Done heres some pics
- 225/60/R15
- Nitrous help
- EFI OR CARBURATED?
- BBK Full Length Headers and then?
- AC HELP PLZZ
- Just got a 95 RAN great. Help?
- windsor power capacity?
- E-Brake Handle, Help
- harmonic balancer
- Best 5.0? Quickest?
- cold air intake
- Drag shocks
- Clutch recommendations
- Gears Humming
- what part is this?
- Weird sh1t going on with timing.
- 331 stroker buildup
- why would my battery be almost below normal and have a stumble
- AC Delete instructions
- ehh i seen this on ebay... good idea or no?
- Looking for Stereo Installer in HOUSTON!
- Oil press loss thru lifters?
- Headlights
- 1990 Factory weight
- 289-302 ENGINE ???
- wheel bearings
- 5.4 ina 88 5.0
- 5.0 EXHAUST
- clutch cable question
- Cam Change
- Got my New MAF
- Quick question about gaskets and heat spacer.
- HELP ME PLEASE!!!
- Quick help on air silencer!
- NOS questions
- injector's
