View Full Version : 5.0 Mustang
  1. headers for GT40 heads ??
  2. Unable to read codes
  3. stupid question but im a newbie
  4. New intake no PLug???
  5. Check engine light and beeping
  6. 86 mustang gt speed density info
  7. Correct gap for autolite #25 ?
  8. Possible good deal.
  9. Mass Air Flow Questions
  10. Tune Help PLEASE
  11. smog pump ughhh
  12. T5 (trans to bell housing bolts)
  13. MOVED: info on my engine?
  14. cobra grill insert
  15. Door Lock Actuators Pics
  16. TKO REAR TRANNY SEAL
  17. Power Steering Install ?'s
  18. swapped over to carb.
  19. heater core hose routing need help!
  20. Rear Seat Backing
  21. Rumbling?
  22. Firewall kit, please explain..
  23. Compression ratio?
  24. Spout location on 94 gt
  25. gauges mileage
  26. Terminator Swap?
  27. swapping everything
  28. Off set rack bushings or not
  29. low voltage!!!
  30. Where to start
  31. tko600 trans for fox
  32. FUEL PUMP STAYS ON AT ALL TIMES , NEED HELP
  33. MOVED: Call it rice, but i like these head lights . .
  34. MOVED: Wider wheel base for wide bodykit
  35. Lookin For OffRoad x pipe
  36. Confused
  37. Prochamber Pipe?
  38. my car is an A-hole: please help
  39. sorry i double posted
  40. temp problem
  41. Engine year
  42. AC delete.
  43. $5000 Left..what should i get done.
  44. MOVED: selling the stang. how much$$$$$$$
  45. 347 Stroker kits???
  46. Need answer quick about MAF
  47. long tube headers intstall
  48. possible cam?
  49. roll cage
  50. Looking for high HP fuel injection advice??
  51. 5 lug swap questions
  52. Off Road Accessory Drive Kit
  53. Sputtering at iddle through out rpm range.
  54. H pipe
  55. new to tunning need help
  56. Do SVO axles fit in an 8.8 rear?
  57. few questions
  58. I need a new a/c condensor
  59. ac delete
  60. 306/w holley kit
  61. 1989 mustang lx fuel pressure
  62. what to do with 1500$$
  63. need help no 5th gear T5
  64. 9 inch axle housing ends
  65. still smelling antifreeze
  66. sputtering after like 4500 rpms
  67. Stock Radiator cooling fan cracks.
  68. Please help 95 5.0 Clunking sound an vibration in neutal and in gear
  69. need help
  70. MOVED: What Will It Run - ET? 89 5.0
  71. Help!!!!
  72. Draglite wheel ???
  73. intake pipe cooler wrap? any one seen it?
  74. tranny q
  75. 302 roller blocks
  76. What do you think of this brake kit?
  77. No Heat...with Overheating...Thermostat??
  78. On the verge of tears...please help
  79. Really noob question
  80. HOW MuCh Hp can????
  81. stock bore
  82. Starter Button
  83. For anyone with a sn95 and mac headers
  84. Gutting the cats on my gt
  85. 75/25 antifreeze mix?
  86. MAP Sensor
  87. serious interior work
  88. Exhaust ? help
  89. 95 GT Drivers Powerseat Motor.....BAD???
  90. EGR Spacer Coolant Lines
  91. ~Camber plates and spring Qs~
  92. BUY A 302.......NEED HELP
  93. Front Runner Drag Tires
  94. quick head Q
  95. Turn Signal Problem
  96. Okay Speed Density people
  97. Charging problems
  98. Are these the same mufflers? "Force" & "V-Force"? (PICS)
  99. On an SD computer, does the Self-test plug, pin 17, ground itself on startup?
  100. rear main leak?
  101. Which heads cam other engine mods
  102. What happened to fullauto?
  103. MOVED: Four Eyed Foxes
  104. Transmission finally took a crap
  105. MOVED: 1977 Cobra II
  106. my 84 wiring
  107. Plz help, 5.0 with "Idle Problem"
  108. Header/Exhaust Question
  109. value spring retainer Q.
  110. antifreeze smell
  111. Soo...How MUCH Nitrous?
  112. got my engine back
  113. ABS ring on axles
  114. twisted wedge heads older casting?
  115. help me i dont know!!!!
  116. 5.slow build question.
  117. so what's up with my car
  118. 5 Lug question
  119. Best intake?
  120. mac starting to piss me off [headers]
  121. bleeding a rack
  122. twisted wedge heads question
  123. 4.6L cobra engine in a NOTCHBACK
  124. 94 5.0 w/vortech
  125. 1988 headlight and fog light problem please help
  126. New Head studs order
  127. Blower won't work
  128. 4cyl springs
  129. Need HELP in Augusta Ga.
  130. Question for the Emmissions State Mustang Guys
  131. a couple of questions b4 i take out the 5.0...plz help dunno mustangs that well yet
  132. header installation
  133. Which short block 306,331,or 347
  134. Starting the car when hot, difficult
  135. Directionals on with Headlights??? Mystery Wire
  136. Change Serpentine Belt
  137. 88 5.0 KIcks!
  138. VIN Number Question
  139. MSD 6a
  140. injectors
  141. How to remove the louvers from GT tail-lights
  142. headlight question
  143. value spring question
  144. head question
  145. Car idle acting up...sometimes
  146. i'm back! and have a question
  147. duraspark 2 with a roller cam
  148. input please!!!
  149. 95GT CCRM / Fuel Pump Problem
  150. Problems starting the car...
  151. MOVED: Lowerd with new tires!! PIC
  152. Tie Rod reinstall
  153. Pillar Pods
  154. t-5 tranny question?
  155. question
  156. msd wiring
  157. which cam 303
  158. nitrous solenoids
  159. Car blows alot of smoke
  160. mass air sensors
  161. Problem need help!!
  162. MOVED: Today driving on a slick street...
  163. accesories on front of motor
  164. 1994 mustang heads?
  165. plate under driveshaft
  166. Conflicting info/opinions
  167. quick question regarding fuel pump...
  168. Oil leak from lower intake ?????
  169. SMELL OF COOLANT
  170. Automatic trans question.
  171. Tech Articles
  172. tire question
  173. Bypassing the air meter
  174. Speedometer correction - more options?
  175. GT40 plugs & wires ???
  176. T5 5th gear upgrade...
  177. SN95 Brake Upgrade
  178. battery light=fuse?
  179. Replacing Steering Rack 95 Gt?
  180. question about mass air.
  181. mass air questions
  182. MOVED: Patriot Heads Valvetrain
  183. MOVED: 347 power output
  184. Different Surging Idle Fix....
  185. exhaust leak after install
  186. Stock Head Curiosity ?
  187. BUILD A 302.......NEED HELP
  188. I need to fabricate a clutch cable
  189. afr 165's or 185's?
  190. 89 Mustang 5.0, NOW WHAT? HELP!
  191. Procharger
  192. Stock fuel pump
  193. Transmission not responding
  194. MOVED: what time do u think i will get at the track?
  195. Boost Numbers?
  196. PICS* Of altenator ....(Need Help_)
  197. electrical problems help PLEASE
  198. cleaning the Engine compartment..
  199. Wheres your ignition box?
  200. What size T/B?
  201. timing questions. need help PLEASE
  202. new guy here
  203. BBK H-Pipe fitment problems
  204. 5.0 Tranny swap auto to man
  205. Question bout Fox weatherstripping
  206. quick fuel line question with pic attatched.
  207. Tweecer r/t any good?
  208. vacuum line for a/c--where does it go?
  209. Tranny fluid?
  210. help!! $%&#^&#%!@$
  211. Has Any One tried This?
  212. MOVED: Stolen '90GT
  213. Convert seat belt removal
  214. Noise when turning the steering to the right.
  215. where is everyone putting their wires when they hide them?
  216. looking for a supercharger......
  217. Need some 302 info
  218. HORRID MISS
  219. how exactly do you build a 302 into a 306?
  220. fuel issue
  221. FenderWall Selenoid Question
  222. AC on but No air.
  223. Gauge Lights
  224. can i change oil pan gasket without removing engine?
  225. crazy headlights, need help
  226. CONVERT TOP AND BLOWER MOTOR BOTH LOOSE POWER
  227. mustang gauge cluster
  228. which spark plugs?
  229. front suspension
  230. Aftermarket Brakes
  231. Ford's with 8.8" rear end.
  232. 110K plus on stock suspension
  233. just got tax returns need suggestions
  234. Next mod
  235. Pilot Bearing During Clutch Swap
  236. oil question ?
  237. MOVED: Where To Buy Pony Wheels?
  238. Fog Light Fix - Easy As Pie
  239. Strange stalling issue, Please Help!
  240. cobra vs gt40
  241. replacing my heating core
  242. will my cobra intake match up to afr heads?
  243. Found HEAD leak...Need help
  244. fuel injectors
  245. a/c cooler
  246. Nitrous engine build
  247. MOVED: Selling 83 GT convertable, have some ?'s
  248. 302 motor swap
  249. what oil for motor break in...
  250. 1994 mustang gt door question.
