View Full Version : 5.0 Mustang
  1. 5.0 turbo
  2. Picked up a stumble
  3. sensor/ground voltages reversed?
  4. running rich please help
  5. seat bolts and nuts
  6. HELP!!
  7. NO POWER AT TOPEND
  8. HELP, I'M AN IDIOT.
  9. Hanging idle?
  10. quick answer on f77e and gt40p casting on heads
  11. 93 5.0 will not run, help??
  12. Couple of general 5.0L Q's
  13. GT40p's and E303 cam
  14. boost pressure regulator help installing
  15. High Idle Problem, please help
  16. help...mustang not starting.........
  17. fuel pump running continuous????
  18. ECM issue
  19. 5.0 mods
  20. Smoking 95
  21. What size are sway bar bushings on 94?
  22. Aftermarket seat and seatbelt Questions
  23. what supercharger?
  24. Condensation in engine, won't start, pissing water out exhaust pipes..
  25. Headlight Problems
  26. dumb oil question
  27. 5.0 potential?
  28. Help with build
  29. Multi-spark ignition... is it worth performance & economy on a stock car?
  30. i finally figured it out the problem
  31. Brakes
  32. sum cam help please.
  33. Electrical Problem
  34. trottle is sticking
  35. Foxbody doors
  36. Timing Cover Cooling Leak
  37. Clunking, shocks?
  38. cam instalation questions
  39. Check engine light removing cats?
  40. pro products intake
  41. turn signal switch, 86
  42. 1990 LX Idle stuck at 2000 RPM
  43. looking to redo the rear end
  44. 89 fox wheel hop
  45. fuel pump relay
  46. what is it worth? 95 saleen
  47. Lowered Fuel PSI and lost?
  48. Tempurature guage problem
  49. Couple questions on swap
  50. 1990 mustang oil pan question
  51. ??what is this?? intake manifold outlet
  52. 5.0 swap for 5.0 HO
  53. spark plug temp range
  54. auto speedo gear
  55. oiling ring question
  56. Installing a B303 on my 94GT..whats needed?
  57. Need HELP finding a new ECU
  58. Valve covers for 94 GT
  59. What should i set my fuel pressure to for best performance?
  60. Cam ?'s.
  61. Where does it read temp. on engine??
  62. Heads? Help me figure out what type of heads I have...
  63. Cooking it down
  64. Tranny Good?
  65. sn95 Suspension on a Fox
  66. Fellow 5.0 fans unite!!!
  67. Exhaust question
  68. More Fuel Guage Questions...
  69. Smokin' Hot
  70. Battery Relocation
  71. stock fuel pump is adequate?
  72. Spedo Cable
  73. bright lights and wipers stopped working
  74. front brake help asap please
  75. t5 swap in 92 notch
  76. afr 165 vs performer rpm
  77. Rebuild vs Crate.
  78. My gas gauge never reads higher that 1/2 tank??
  79. Cheap AmericanMuscle CAI vs expensive BBK CAI?
  80. Clunking in Manual Trans!!??
  81. maximum cam lift with stock springs?
  82. BBK SSI Intake spacer question!!
  83. help asap
  84. water pump
  85. Overheating
  86. Edelbrock SDT Sound Deflection Tech. Mufflers Any Good on Fox Mustangs?
  87. suspension quesion...
  88. Can someone edjumacate me on wideband O2 sensors
  89. dumb question
  90. 98 Mustang Parts on a 92?
  91. head gasket question
  92. thermostat
  93. Need Tune?
  94. Wiper problem
  95. laggy
  96. Fuel pressure question
  97. AFR heads
  98. springs
  99. motor mods
  100. oil question
  101. noise from clutch
  102. It will only run with the Spout Connector off
  103. best place to mount fuel pressure regulator
  104. Manual rack options
  105. Turbo?
  106. May be a stupid question but.....
  107. another water pump thread
  108. Water pump opinions wanted
  109. throttle body sticking
  110. exhaust / sound of car
  111. agx ADJ shock fitment
  112. e7 heads
  113. clutch or trans??....
  114. motorvac vs other cleaners?
  115. Picked up some Gt40p's. Which longtubes fit?
  116. Blower Motor Short?
  117. tire size help
  118. Help...Wheel Hop
  119. 6 INCH COWL ANYONE?
  120. Clunk/clank sound?! Help!
  121. loose steering wheel and top part of column
  122. Anyone Seen This? Somebody's got to know!
  123. Edelbrock performer RPM heads
  124. Cheaper Manual Steering Conversion
  125. Off H? or Off X?
  126. Wheels 10.5
  127. car list of compatible aod's
  128. Head Gasket?? need help big time
  129. Venom 400 Performance module
  130. Steeda 19
  131. update 180mph speedo
  132. Steering wheel & body kit questions.
  133. lentech valvebody question
  134. balancer removal
  135. sqeaking problem
  136. Which Cam??
  137. rim/tire size question
  138. Need help wiring electric fan!!!
  139. MSD question
  140. tranny question
  141. 1/2 to WOT backfires and bogs down.
  142. quick question
  143. what fuel filter is this?
  144. overheated now oil leak??
  145. question about gears and relocation of battery
  146. Everything keeps going wrong
  147. lost 5th gear
  148. Hi im the new guy.. i have some questions :)
  149. Fuel pump or reg? maybe something else?
  150. DAM RICERS!!!
  151. Now what?
  152. Input on mpg effectiveness for these modifications
  153. which mid pipe is the best
  154. Couple of questions
  155. ? on a crown vic 5.0
  156. burnin oil?
  157. Anyone had to replace Rack & Pinion on 1987 Fox GT
  158. Rear wheel bearing removal
  159. Ignition problems
  160. Clutch Problem
  161. GT40 Iron Head Plug Question
  162. Gas Gauge
  163. 180 mph speedo
  164. 2 step limiter
  165. Emergency tire size question!!!
  166. suspension work
  167. how to take a motor out?
  168. DARLINGTON DRAGWAY
  169. HELP!!! FIRING ORDER 5.0L PLEASE!!!!!
  170. ok guy i need help bad!!!!
  171. HOW LONG DO A FUEL PUMP LAST?
  172. car broke valvetrain????
  173. hard gas pedal
  174. Patriot heads?
  175. supercharged!
  176. Dilemma to keep or not to keep
  177. still got a miss, but i got the codes
  178. Strange Steering Problem ?
  179. airbag light
  180. Throttle Body help Please!
  181. 79 to 93 Mustang/Capri Hatchbacks rearseat Delete
  182. LSD?
  183. code readers
  184. BAD FUEL PUMP OR REGULATOR?
  185. T5 rebuild
  186. 5.0 rearend
  187. wierd tranny problem(tranny just rebuilt)
  188. Anyone used a Magnaflow cat-back system on a FOX?
  189. aod / t5 swap
  190. i found out the miss
  191. BBK Headers
  192. Port and Polish intake
  193. 2 questions, flywheel, and stock motor Q
  194. cant figure out this miss
  195. i need help with my after market tach
  196. intake setup
  197. still have a slight miss
  198. Pony Rim Contacting A-Arm
  199. changing the spoiler
  200. What Oil ?
  201. 95gt pinging/backfire
  202. paxton sn-93
  203. Clutch Cable/Shifter Advice
  204. Overheating issue....
  205. o2 sensor?
  206. Vortech Intake Manifold
  207. ? about building a 306?
  208. new build opinions
  209. flywheel question
  210. syncros in td replacement
  211. socket size?
  212. What wheels do I need?
  213. JE SRP Pistons???
  214. h/c/i questions
  215. Speedometer problems
  216. Car won't start
  217. Copper Head gasket
  218. Replaced my heater core, still smells
  219. Fuel pump and other wiring ?
  220. tranny ?......
  221. T5 Cluster Gear
  222. 87 5.0
  223. help::::::new computer::::code 94/44
  224. Crate motor
  225. 94 E250 5.8 PROBLEMS
  226. 89 mustang Engine vibration
  227. JEGS cylinder heads
  228. anyone know if the cobra 5.0 intake mani.
  229. Stupid Newb Question about Turbos...
  230. clutch ?
  231. 9" swap
  232. converting a gt to a lx
  233. Keep blowin my dog teeth in 3rd gear
  234. 93 4cyl to 5.0 - final list
  235. gt-40 svo heads wat plugs to use
  236. c&l mass air meter, good or bad?
  237. sn95 cobra drivetrain upgrades
  238. THANK YOU JOEL
  239. Are Magnaflows any good?
  240. GT fender extensions
  241. 91 GT 5 LUG CONVERSION
  242. head removal advice please?
  243. HOLY SH*%
  244. Multifunction switch problems
  245. 84 nose on a 91 lx
  246. Best Cold Air Intake?
  247. Stalling, idle with foot on gas, dead spot @ half throttle
  248. factory catback exhaust tubing diameter
  249. Lowering a 91 convertible 5.0
  250. 11 sec mustang???
